Dropped Rocker Arm Oil Deflector
Old 10-08-2010, 01:38 PM
Z28Power's Avatar
Default Dropped Rocker Arm Oil Deflector
I was trying to adjust the rocker arms on my lt1 camaro because there are a few that are making a ticking noise. I was putting on the Rocker Arm Oil Deflector Clips when one sliped and fell into where the push rod comes out, i heard it fall inside the motor when it hit it sounded hollow. Im not sure what to do to get it out any ideas???
Old 10-08-2010, 01:58 PM
RamAir95TA's Avatar
The most straight-forward method would be to remove the intake manifold and grab it. It's unlikely it made it any farther than that. But if you didn't want to go that route, I would use a thin lighted boroscope and a flexible magnet and go fishing.
Old 10-08-2010, 03:51 PM
SexyTransAm's Avatar
try fishing first.
Old 10-08-2010, 04:53 PM
Z28Power's Avatar
anyone know where i can find a boroscope ive called everywhere nobody knows what they are -_-
Old 10-08-2010, 05:01 PM
RamAir95TA's Avatar
It's a flexible snaky-like camera (either with a screen or just an eyepiece and uses ambient light, those are the cheaper ones). Most auto shops have decent ones, but they are very expensive. Maybe you can find a shop kind enough to let you borrow it, or maybe you know a friend who might have one. I have one, so that's why I said "I would use..."
In all likelihood though you might have luck just fishing with a magnet.
Old 10-08-2010, 05:02 PM
RamAir95TA's Avatar
http://www.google.com/products/catal...d=0CGIQ8gIwAQ#
Old 10-08-2010, 05:44 PM
Z28Power's Avatar
theres no way its coming back up the way it went down -_- theres a metal shield that the push rod goes through and it went up and over that shield... i tried a telescoping magnet but it got jammed in there and i dont wanna try that again is there any smaller telescoping magnets?
Old 10-08-2010, 05:50 PM
RamAir95TA's Avatar
What shield? If it went down a hole it can come back up a hole. Like I said though, if you can't get it you'll have to pull off the intake manifold.
Old 10-08-2010, 05:59 PM
Z28Power's Avatar
it went up and over the thing the push rod is going through, the magnet got jammed when coming back up i doubt ill be able to pull anything back up through there.
Old 10-08-2010, 06:21 PM
Z28Power's Avatar
when it fell down it fell down next to the third push rod in from the left at the bottom, there is a metal shield down there i believe cuz i heard it when the magnet touched it so i guess im going to have to pull off the intake manifold, any idea on what things im going to need? i have no egr system just a block off plate in the back and ive already done the tb bypass.
Old 10-08-2010, 07:37 PM
RamAir95TA's Avatar
I'm still confused. Your terminology is a bit confusing. Look for a better picture of this hole and mark it in MS Paint then upload it to an account, if you can. From what I can gather it sounds like you lost it down an oil return passage or into the lifter valley.
Old 10-08-2010, 08:31 PM
Z28Power's Avatar
this picture shows the hole it went down, but there is like a plate or wall behind that hole, the clip went up and over the wall or plate behind that hole
Old 10-08-2010, 08:38 PM
Z28Power's Avatar
this is an edited picture showing where it probably fell to
Old 10-08-2010, 08:55 PM
Z28Power's Avatar
this image shows the thin wall that the clip went over.
Old 10-08-2010, 09:41 PM
bigj2717's Avatar
I would just pull the intake and look for it. If it fell further down in the motor then youll have a lot more work to get it.
Old 10-08-2010, 09:45 PM
jester1614's Avatar
good pictures lol
Old 10-08-2010, 10:00 PM
Z28Power's Avatar
Originally Posted by jester1614
good pictures lol
what do you mean?
Also what will i need when pulling the intake manifold? Like which gaskets tools etc?I have a repair manual i picked up from auto zone a while ago when i did the opti but it doesnt tell tools just tells you how to take it off.
Old 10-08-2010, 10:15 PM
bigj2717's Avatar
You just need sockets and a ratchet the only special tool is the fuel line disconect tool which you can get a pack at auto zone for like 5 buck. For gaskets you can get and intake gaskest set at auto zone and itll have everything you need
Old 10-08-2010, 10:24 PM
1badzee's Avatar
That shield you are referring to is the headgasket..
Old 10-08-2010, 10:56 PM
JAKEJR's Avatar
Yep.
Jake
Quick Reply: Dropped Rocker Arm Oil Deflector
