408 teardown, need expert opinions
Old 10-10-2010, 12:39 AM
I need a gauge for that
Atomic's Avatar
Default 408 teardown, need expert opinions
I usually post over on PT, but I know there are a lot of experts over here.
Backstory:
I bought an assemebled 408 shortblock in april, and spent april through august collecting parts to throw it in my truck. I installed it in the middle of August and have been driving it since. Last weekend I noticed I was having low oil pressure so I cut open the oil filter and found a lot of little copper colored shavings. Damn. Soooooo I pulled it out this weekend and put my 5.3 back in, and now I have to decide what to do...
Parts list:
LQ9 iron block
K1 4.00" stroker crank
Diamond flat top pistons 4.03"
Callies compstar 6.125" rods
11:1 compression
All ARP hardware
LS6 oil pump
Pat gold dual springs
REV 2.02/1.6 valves
317 heads
LS9 headgaskets
Pat G custom cam
rollmaster double timing chain
LS7 lifters
Hardened comp pushrods
In total I had 1700 miles and 1.5 months of use from this engine. I put my tvs1900 on it and damn it was fun while it lasted. I bought the shortblock fresh from the machine shop from a guy that was getting deployed and changed his mind or something. I spoke with the shop before hand and they seemed competent enough...
party in the pan,
main caps, front on the right,
crank,
pistons,
combustion chamber,
Comments
-The cam is in good shape; no wear on the journals, although obviously im going to replace those bearings as well.
-The pistons are not nearly as clean as I was expecting for so few miles...
-The cylinder walls are smooth as glass.
Plans
Even though I didnt have the 408/tvs1900 combo for very long, I maxed out the blower with a 2.8" pulley and got around 7lbs of boost and while it was fun, it was also kind of boring. Based on the time I ran at the track, never got a chance on the dyno, and the weight of my truck it put down right around 600rwhp. So I am going to sell the blower and go with an 88mm turbo setup at some point, but more pressingly I need to get this engine working again since I have too much cash in it for it to be a garage ornament.
I am hoping the crank is fine and just needs a little polishing (cant feel any score marks with my fingernail), and I can use it along with the rods. I am thinking I want to go with dished pistons to put the compression ratio at around 9.5 for 12+ pounds of boost.
Are there any engine builders near Alabama that anyone recommends? I would prefer someone within driving distance so I wouldnt have to worry about shipping this thing via freight. If there arent, does a performance shop like HKE redo failed builds or what? I want the block align honed and all bearings replaced and clearances checked as well as runout on the crank checked; basically I dont want this to happen again for at least 100k miles.
I know this is long winded but I like being thorough.
Thanks for any input
Old 10-10-2010, 01:41 AM
02 BLK WS6's Avatar
Tear everything down. Send block the machine shop and have the heads decked, crank polished, mains line honed, bores honed, and new cam bearings installed. Clean up the pistons and install a new set of rings.
From the looks of it, the mains weren't line honed before assembly.
Old 10-10-2010, 02:15 AM
Duffster's Avatar
heads and piston faces look fine. . .
clearly your bearings are thrashed. Just wait until you see the piston rod journals. . .
Old 10-10-2010, 09:41 AM
Atomic's Avatar
Speaking of which, I am having a hell of a time trying to get the rod caps off....any suggestions?
Old 10-10-2010, 10:48 AM
SOMbitch's Avatar
Wonder if they are torqued to spec??? I had to put a little *** in it to break mine loose but not that hard. IIRC the ARP torque specs are around 40-45lbs....
Old 10-10-2010, 11:35 AM
KCS
Moderator
KCS's Avatar
I'm guessing those are Clevite bearings? It looks a lot like #3 bearing clearance was too tight (typical of Clevites) and judging by the wear on both outer edges of the other bearings, there may have been some serious taper in the journals.
As for the rods, there is a dowel in the cap that has a press fit with the rod end which makes it difficult to pry the two apart. All you have to do is loosen the bolts out a few turns and tap them with a rubber mallet. That will seperate the rod.
With Compstars, the 7/16" rod bolt torque should be closer to 75-80ft-lbs as well. 40-45ft-lbs is typical of the smaller 9mm or 3/8" diameter bolts.
HKE has basically built a reputation for fixing builds from other shops that didn't live up to the customers' expectations (i.e. last more than 800 miles, etc). Erik and his gang can certainly get you lined out with a nice trouble free engine, so long as it's well maintained and well tuned.
Old 10-10-2010, 12:10 PM
Atomic's Avatar
Got them out with a rubber mallet, not too bad. Bottoms of the pistons look brand new, and the rod bearings on the crank dont look bad.
Cylinder walls are good,
The dark spot on the center journal is oil.
HKE was the first shop that came to mind, but has any one ever used Hinson performance in Hunstville, AL? I would like to avoid shipping if possible, and Hinson specializes in LSx engines.
Old 03-26-2014, 10:49 AM
69c4x11's Avatar
Reply,,, Who did you end up using for your machine shop ??
Old 03-27-2014, 11:35 PM
Atomic's Avatar
Bryan at LME
Old 03-28-2014, 04:24 AM
vaethshuxun's Avatar
Old 03-28-2014, 07:39 AM
Atomic's Avatar
Loosen the bolts but dont take them completely out, then tap on the head of the bolt with a mallet alternating sides so it comes off evenly. Then when its loose keep taking the bolts out.
Old 03-28-2014, 10:54 AM
KCS
Moderator
KCS's Avatar
It's a spammer/bot/etc. It just repeated what you said in this thread, and in a couple others too.
Old 03-28-2014, 12:35 PM
Atomic's Avatar
Ah, thanks. Slapped him with the ban hammer.
Old 03-30-2014, 01:05 PM
Sales@Tick's Avatar
We don't use Clevite main bearings for this exact reason. We use ACL main bearings and Clevite rod bearings.
Always tight on the thrust...
Wow I just saw this was from 10'!!! lol
Quick Reply: 408 teardown, need expert opinions
