Motor Mounts
here's a pretty good thread on the poly motor mounts:
https://ls1tech.com/forums/showthrea...t=motor+mounts
Originally Posted by Nasty N8
Madman won`t sell them any more cracking blocks. Use Prothane urathane mounts. We also stock them.
Nate
Nate
get an old pair of mounts before you do the prothane. That way you can make the prothane (they use the existing clamshell) before you start your endeavour. maybe some shop can throw you some old mounts for free.
i didn't know the prothane required the existing clamshells till i read the docs. i just let the mechanic handle it.
Nate
Nate
Dope
I have poly mounts also. changed them at same time as I swapped motors so it was pretty easy. I noticed some increase in vibration, but I installed the poly tranny mount at same time so that could be the culprit.
