crack oil pan
crack oil pan
Need help on this one im not to mechically incline ..just trying to see what yall think before i take it to the shop.My wife went to start her 2002 trans am an it made a loud noise so i look under the car and the oil pan is crack bad! Thanks
I have heard of this happening, but from what I remember the damage is usually more extensive than the pan. Pull the starter and check the block for damage. I seem to remember something about an ear breaking off of the block.
no if theres a cracked pan thats not good if theres oil everywhere thats worse if theres a hole thats terrible. what happened did the engine shut itself down or did it run until you cut it off
https://ls1tech.com/forums/general-m...ock-broke.html
Hopefully yours does not have the same problem.
Was it raining just before this happened? Because they all leak water past the cowling onto the engine. If any injector orings or the intake gaskets leak a little and let rain water into the engine. The high reduction starter GM uses will allow a simple hydro lock to turn into a broken block. Good Luck
