What all can cause no spark?
Old 12-22-2010, 11:08 PM
za355tx's Avatar
Default What all can cause no spark?
I've got a 94 formula I'm trying to get running and it has no spark. It has a fresh opti I know is good, a new coil, and an ICM that I know works, but I still have no spark and I'm trying to figure out what else could cause no spark. I've tried searching this but didn't find anything that was exactly like what I have. All I found was the typical opti going bad, or a bad coil, or a bad ICM. Since I know all those are good I'm a little confused now. The sooner I get this car running the better as it's my only means of transportation and bumming rides is getting old. Thanks a bunch in advance guys.
Zach
Old 12-22-2010, 11:15 PM
defaultexistence's Avatar
that
http://shbox.com/1/95_ign_system_schematic.jpg
or some of that
http://shbox.com/1/4th_gen_tech2.html#opti_test
or maybe that
http://shbox.com/1/pass_key.html
Old 12-22-2010, 11:22 PM
MattSapp95_T/A's Avatar
only things I can think of is
Opti
opti harness
ICM
Coil
PCM
Did you check for fire at the coil??
Matt
Old 12-23-2010, 10:17 AM
za355tx's Avatar
I did not check for spark at the coil I checked it at the opti. I will double check for spark at the coil just to be sure. The coil is brand new so I'm positive it's not a coil problem. The opti harness looked pretty good but I guess I should try another one just in case since I have spares.
Old 12-23-2010, 11:16 AM
How did you check the ICM?
Old 12-23-2010, 05:01 PM
za355tx's Avatar
We had one that came off a working car that we tried and still no spark.
Old 12-23-2010, 06:56 PM
jasonz28camaro's Avatar
try this if shbox didnt work.
http://www.mainstreamtopics.com/foru...p?showtopic=78
Old 12-23-2010, 08:30 PM
za355tx's Avatar
I will take a look at that and run through it. Thanks man.
Old 12-24-2010, 01:51 AM
red93z28lt1's Avatar
also lots of crossed wires is an option
Quick Reply: What all can cause no spark?
