Should i re use my lifters off my ls2
Old 01-04-2011, 10:08 PM
firehawk68mcleod's Avatar
Default Should i re use my lifters off my ls2
I have a ls2 with around 30,000 miles on it.. should i reuse my factory roller lifters when i do my cam swap? I know u always replace them with solid lifters.. but since there rollers i wasnbt for sure .. let me know thanks
Old 01-05-2011, 09:25 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
At 30,000 miles it would not be required to switch them out. Some people might jsut to have a fresh set but I would still expect decent life out of some that only have 30k on them.
Old 01-05-2011, 10:14 AM
litle88's Avatar
Just spend the 125 and get you some new lifters, your there already. Just my .02
Old 01-05-2011, 05:01 PM
well if i was doing a modist cam i would run the stock lifters but if i run a bigger cam... at which point should i run aftermarket lifters at which point do you not use factory lifters
Old 01-05-2011, 09:13 PM
litle88's Avatar
What are the cam specs?
The gm lifters should be fine though unless it's one radical cam and you'll be spinning it to 7500?
Old 01-05-2011, 09:39 PM
Wat cam did you go with.. whats all done to ur engine... I kinda want this car streetable.. i have a procharged 68 ls2 camaro im building. I wanna keep this car my driver with a small cam
Old 01-06-2011, 08:15 AM
LS1Tech Sponsor
Slowhawk's Avatar
If your not pulling the heads- leave them in. There are thousands of cammed cars out there with over 100k on the stock lifters.
If the heads are off I would change them for peice of mind.
Old 01-06-2011, 04:46 PM
FryZ71's Avatar
Hope I get good miles out of mine, but there's alot cammed LS2 lifter failure threads on LS1GTO. Makes me nervous, although I only have 23K...18K of those miles cammed.
Old 01-06-2011, 04:51 PM
I hear you there.. are ls2 and ls1 lifters the same
Old 01-06-2011, 07:49 PM
litle88's Avatar
Gm now uses just one set of lifters on all exept for the dod motors. They are the same as the Ls7's.
Old 01-06-2011, 08:07 PM
whats different bout the ls7 lifters.... and DO those run $125 for a set from gm... i get gm discount as well
Old 01-06-2011, 09:55 PM
litle88's Avatar
When Gm designed the Ls7 they redesigned the lifters and GM just ended up using this design across the board on all their Ls motors exept the DOD ( displacement on demand) motors. They are part# 12499225
Old 01-06-2011, 10:10 PM
Thanks ill run that part number by my local dealership thanks
Quick Reply: Should i re use my lifters off my ls2
