New PAC springs
Old 01-04-2011, 09:14 PM
serpentnoir's Avatar
Default New PAC springs
Looks like PAC has new springs in their 2011 catalog: 1219 and 1519. Both beehives.
Has anyone seen those, prices?
Old 01-04-2011, 10:22 PM
Wicked94Z's Avatar
I saw these a few weeks ago, look at the spring mass compared to the 1518s! I hope the coil bind is conservative like the 1518s.... If these will repeatably go 1.080 I'd like to to throw .650 at them and spin 7200+ even with solid stem valves.
Old 01-05-2011, 11:09 AM
cam
cam's Avatar
Interesting. I have a new set of 1518's for an L92 build but wonder if its worth the investment to step to these instead? Anyone using these yet?
Old 01-05-2011, 01:22 PM
lumpytag's Avatar
I'm not, but they are looking great for sure. I'd say its worth.
Old 01-05-2011, 04:42 PM
Stang's Bane's Avatar
They also have several new double springs that look nice as well. I would look at them for a l92 build
Old 01-06-2011, 07:02 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
So better seat and open pressure, AND less mass. Sounds like a winning combination for some high rpm motors.
Old 01-06-2011, 11:44 AM
I spoke to Al at PAC and the new springs will be available at the end of February.
Old 01-06-2011, 03:01 PM
cam
cam's Avatar
I typically run duals regardless but on this build Im retaining VVT and apparently the phaser struggles too hard against big pressures so....
Singles it is. Might just run the 1518's and go but I will certainly keep an eye on these and build threads that run them
Old 01-06-2011, 03:50 PM
v8pwr's Avatar
PAC has several new springs for LS engines that look like they'll be pretty awesome . There's even a small diameter spring that could be used for moderate solid roller applications . I think they had some exciting stuff @ PRI .
Old 01-06-2011, 04:23 PM
WKMCD's Avatar
I wish they had nitrided some of the new springs. The 1518's and the 1521's look like they remain the only drop in nitrited spring.
Old 01-06-2011, 08:46 PM
Wicked94Z's Avatar
the 1519s are nitrided
Old 01-07-2011, 05:48 AM
WKMCD's Avatar
Yup. I only looked at the bigger springs. I run the 1521's.
Old 01-07-2011, 10:33 AM
cam
cam's Avatar
Hmm maybe that will come. Im definitely running the 1518's now I didnt read closely enough to notice the new ones are not nitrided. Neither were the 1518's initially they were just the 1218's ( 12 iirc? ) regardless the version thats the same less nitriding.
Quick Reply: New PAC springs
