Should i re use my lifters off my ls2
I have a ls2 with around 30,000 miles on it.. should i reuse my factory roller lifters when i do my cam swap? I know u always replace them with solid lifters.. but since there rollers i wasnbt for sure .. let me know thanks
well if i was doing a modist cam i would run the stock lifters but if i run a bigger cam... at which point should i run aftermarket lifters at which point do you not use factory lifters
Wat cam did you go with.. whats all done to ur engine... I kinda want this car streetable.. i have a procharged 68 ls2 camaro im building. I wanna keep this car my driver with a small cam
Hope I get good miles out of mine, but there's alot cammed LS2 lifter failure threads on LS1GTO. Makes me nervous, although I only have 23K...18K of those miles cammed.
