No traction with stall. Will nitto 555r dr's help? Vid inside
Old 01-16-2011, 01:24 PM
Restricted User
z99ls1's Avatar
Default No traction with stall. Will nitto 555r dr's help? Vid inside
So I have 315 sumitomo's on my car now, that didn't hook very good on the stock stall. Im wondering if some 275 nitto 555r drag radials will get me hooking right up off the line?
Here is a vid for reverence
http://www.youtube.com/watch?v=Lm0aAzwqWeo
Old 01-16-2011, 01:37 PM
itSSlowZ28's Avatar
how much do you drive it on the street? unless its on the street a lot, i'd get something a little stickier. m/t's or bfg's
Old 01-16-2011, 04:51 PM
Restricted User
z99ls1's Avatar
Its a dd. It is 99% street and 1% track, but I do alot of messing around on the street and I heard this was a good tire to hook on the street and lasts awhile.
Old 01-16-2011, 04:57 PM
allbaugh_04's Avatar
http://www.youtube.com/watch?v=QbTsbEOBtBs
On nittos
Old 01-16-2011, 05:01 PM
Trl_ws6's Avatar
I love my nittos but you have to heat them up to really hook.
Old 01-16-2011, 05:33 PM
pancho toco loco's Avatar
wow that was a sub 5sec 0-60 on the street
Old 01-16-2011, 09:28 PM
Restricted User
z99ls1's Avatar
Im thinking about getting my wheels widend an inch so I can get the 315 nitto dr's
Old 01-17-2011, 08:28 AM
joblo1978's Avatar
IMHO and from what luck friends of mine have had with 555R's is they generally suck for any kind of traction at the strip. They are marginally better than a street tire and they run narrow in their appearance.
I really think the BFG drags would fit your needs better than a Nitto. Now those are badass tires!
Old 01-17-2011, 08:46 AM
joblo1978's Avatar
Originally Posted by allbaugh_04
Yeah, spinning all the way through first with an auto....like I said, they suck.
I've cut a 1.8 back in the day with BFG's on a 35 series 18" wheel, stock weight 6 speed and 3.42's.
I went 2 seasons on them with big smokey burnouts and daily driving. I still have them in the garage with lots of life in 'em still. Great tires!
Old 01-17-2011, 09:03 AM
thunderstruck507's Avatar
They helped me a lot, still won't dead hook but they would stick at least twice as good as any street tire.
At the track I cut 1.78 60ft launching as hard as I could and spinning just a hair as a result. I doubt even with full slicks I could have got any better than 1.69.
Mine were 275/50/r15. Lasted around 15000 miles and I took them off because the middle was worn enough they were dangerous in wet weather. I could still use them at the track another 2-3 trips I think...if they haven't gotten too hard from sitting.
Old 01-18-2011, 12:58 AM
Restricted User
z99ls1's Avatar
I think im going to with the 275 nitto dr and do some suspension and hope I can hook
Old 01-18-2011, 03:39 AM
blackls1ta00's Avatar
get mickey t's and be done with it
Old 01-18-2011, 06:34 AM
Trl_ws6's Avatar
I love mine once again. I have cut 1.42 at the track on 275 555r's
Old 01-18-2011, 07:01 AM
BODUKE's Avatar
I have 555r's and they are great. At the track you gotta heat them up good.
Old 01-18-2011, 11:07 AM
I daily drive my Chevelle and wouldn't be ok with the life and softer sidewall of the mickies
Old 01-18-2011, 11:22 AM
SexyTransAm's Avatar
iv cut a 1.76 60' on 275/50 nitto 555r, that was cam only untuned on motor. oh and BFGs suck!
Old 01-18-2011, 12:01 PM
Restricted User
z99ls1's Avatar
This is for my street tire. And I want to get atleast 10,000 miles out of the tires. So those are not really an option
Old 01-18-2011, 08:09 PM
STREET99's Avatar
I am running my DD Bolt-on car right now with 275 MT's and never have a problem and they show no real signs of fast wear. The next set of tires I am planning to get, since I have heard from so many people and big name people on these forms are these:
I heard "TRUST" on these Fourms had them on his 800+HP WS6 with I think a 315 size Toyo and he said they held up really good. They say they last almost longer then a Nitto and are nearly as sticky as a MT. I would Search the fourms on here for more info.
Old 01-18-2011, 09:56 PM
Restricted User
z99ls1's Avatar
How much a tire?
Old 01-18-2011, 10:22 PM
They are reasonable, try onlinetires.com i believe.
Quick Reply: No traction with stall. Will nitto 555r dr's help? Vid inside
