17x11 w/spacer??
17x11 w/spacer??
I have been looking through alot of pics with 17x11 OE wheels and it looks like the rear wheels are tucked into the car just a touch, or is it just the pics?
I have the wheels ordered and was considering getting a small (1/4" or so) spacer to set them out just a touch.
I have no problem with the BFHing the inners wheel wells and I will be rolling my fender lips, I want the tire to be able to tuck, but also want it to fill out the area.
So spacer or am I just being crazy
I run a 1/4 spacer with longer ARP wheel studs and it will fill out the wheelwell nicely (50mm 17x11 ZR1s). I rolled my fenders and did the BFH mod before I ran the spacers. I also have a double rod ended PHB.
Edit: I have no rubbing.
Thanks for the reply
Sorry, no pics. My rear ZR1s are flush with the quarter panels. The bodies on the Camaros are wider before the rear wheelwells. If you look straight down from above the rear wheelwell the body gets narrower towards the back bumper. So I think depending on the angle you are looking at the car it may look like the rear wheels are sunk in versus looking like they stick out from the back.
subscribed!
closest thing i have found on here so far that is on the topic of flushness.
i've got the 17x9.5 10 spokes but want something much more aggressive (18x10/11).
i had 18x9.5 front and 18x10.5 rear on my 240sx and it was superflush.
want to get close to that on my z28. i know its harder with a solid axle and needing more meaty tires, but i hate the sunken wheel look. i would consider spacers but for a 9.5 wheel im better off putting that money towards new wheels.
do we have anything close to a "flush fitment" thread here? off to the search...
Well as soon as my retarded employer deposits my check I'm ordering my spacers and a bunch more parts.
I don't have tires yet, but hopefully in a month or so I'll get those here, have some other stuff on my list first before tires are needed.
Yes but you HAVE to have and adjustable PHB, rod ends on both sides is prefered. It fits better on a Firebird but they do fit on camaros too, but if you using a wide tire it might stick out
keep in mind, the rear fenders of the 'birds stick out just a hair more than the camaros
Would the same go for any other brand wheel? The wheels I'm looking at have 3.5" lip (11" wide wheel) at +50, if I wanted to make it more flush with a +36, do you know how that would change the lip size? Also, if I go anything under +50, what I'm doing is bringing the wheel out more toward the fender?
Trying to grasp the concept of wheel offsets and widths. Thanks!
I have an adj. phb, right now the wheels sit perfectly even on both sides.
But after seeing the pics of the 36mm offset I'm going with a 1/4" spacer
Thanks alot guys for the replies
But a 54mm offset would put the wheel into the car even farther. If they came out with a wheel with a 45mm offset or so I think it would be about perfect.
Now if I use a 1/4" spacer (6.35mm) that would give me an offset of 43.65, pretty damn close to 44 if you ask me And I think thats a happy middle between the 50mm and the 36mm offset.
But either way I'm ordering the spacers today along with the rest of the parts to complete my rear axle, someday I'll get some pics
The body of these cars just don't look right with a flush fitment, it starts to look donked. The +36mm on the camaro in that link up there ^ sits flush, but looks like its sticking out of the body in every angle. I think +40 to +44 is the best way to go.
