Z06 valves?
Old 04-06-2011, 09:09 PM
blakss's Avatar
Default Z06 valves?
Was wondering if anybody went thru the trouble to run Z06 valves? Is it worth it ? What do you guys think?
Old 04-06-2011, 09:12 PM
Rossko85's Avatar
valves as in exhaust and intake...or valve springs, guides what? Your throwing me here with the valves...didnt know there were any differences...are they made up of different material or what? I would imagine that is probably the difference...
Old 04-07-2011, 01:19 AM
DavidGXP's Avatar
The zo6 valves are soduim filled do they are much lighter the the valves we have. This would allow the valve train to rev quicker and bemore stable at high rpms.
I dont think you would gain much by switching without swsping cams.
Old 04-07-2011, 02:48 AM
blakss's Avatar
Yea I ment as in intake and exhaust valves.. And yea davids right they are sodium filled and exhaust is hollow. And I believe a little bigger then our stockers. And well I'm looking to get some head work and I'm looking to sway out the valves all together jus not sure if its worth it or not but I think I am gunna run the ls6 setup.
Old 04-07-2011, 08:56 AM
LS1 Racing's Avatar
You'd need a bigger cam to take advantage of the benefits offered by lighter/larger valves.
Old 04-07-2011, 05:18 PM
blakss's Avatar
Yea I know but that's after the head work,DOD delete and intake swap.
Old 04-07-2011, 05:21 PM
blakss's Avatar
Would anybody happen to know the size and length . I believe its 204 for exhaust and 168 for intake but I can't remember exactly.
Old 04-08-2011, 10:14 AM
DavidGXP's Avatar
ZO6 5.7 LS6 valves are not bigger.We have the same size valves..
Old 04-08-2011, 11:22 AM
DavidGXP's Avatar
Go with a the dod delete kit, LS6 valves and use titanium retaniers for some serious valve train weight loss!
Old 04-08-2011, 01:49 PM
blakss's Avatar
Got somethin like that in mind. If I piece together the DOD delete kit is it basically lifters,trays and gaskets or is there more to it besides the ls2 valley cover?
Old 04-08-2011, 08:54 PM
Panther427's Avatar
Um i thought we had issuse with using larger valve due to our smaller bore diameter
Old 04-08-2011, 09:41 PM
vroom_vroom's Avatar
drill baby drill.....................
