General Maintenance & Repairs - car accelerates son its own!!!!!!
View Full Version : car accelerates son its own!!!!!!
groundZ-28ERO
05-06-2011, 07:16 PM
my friends o2 z28 likes to accelerate on its own right after he startes it and puts into drive. wtf, i cant figure it out.
zacht
05-06-2011, 07:29 PM
really bad brakes???
lol, you need to be more specific...
Sumter
05-06-2011, 07:32 PM
High idle?
blitzace12
05-06-2011, 07:34 PM
TPS? Tell us more...
groundZ-28ERO
05-06-2011, 07:43 PM
you start it put it in D, it gos without pressing the pedal, then when you push the pedal it doesnt accelerate sometimes, then when you let off the gas it wants to by itself, its wierd
maybe dirty maf, or the sensor on the throttle body that calculates how far the throttle is open is shit.
maybe the fuel pump or fuel filter is bad and or dirty
01ssreda4
05-07-2011, 03:09 AM
Is the car modded or stock? Whats the idle rpm when its doing this?
jsteele90
05-07-2011, 03:16 AM
sounds like a high idle too me
poltergeist 02
05-07-2011, 09:39 AM
check the iac see if it's all gunked up.
LS6427
05-07-2011, 01:03 PM
There isn't a single electronic part on the car that can open the throttle blade to let more air in. The only way an engine can accelerate without you doing it is if more air gets into the intake than should be there. Therefore, you have a very strange vacuum leak that only leaks when you take your foot off the pedal.......or you need a new IAC valve. As mentioned, it is possible to clean it IF the problem is from the IAC valve being very dirty and its wigging out. Just take it out, don't touch the spring or unscrew it....just spray the piss out of it with MAF cleaner, WD-40, or the like, and bolt it back up to the TB. If it looks clean, go buy a new one and try it out. If it doesn't work take it back for a refund, just tell them it does not fit your TB.
O2Form
05-07-2011, 01:10 PM
The cruise control can........ and i heard of a few instances where people claimed the Traction-Cruise control caused the car to accellerate on its own.
groundZ-28ERO
05-07-2011, 05:48 PM
ill try and take the iac out and see what that does.
groundZ-28ERO
05-07-2011, 07:34 PM
the IAC was filthy dirty, cleaned it and the car runs fine:smokin2:
groundZ-28ERO
05-23-2011, 08:32 PM
it was a crushed o2 sensor
