what 18s are you running with c6 z06 brakes
hey guys im wanting to put c6 z06 brakes on my 98 ws6 and want to stick to 18s all around i was wondering what wheels i should run that not only look good but also clear those big brakes. i do love a flush offset with the fenders as well thanks for the help!!
Just about any wheel could work but you would have to use spacers to clear the calipers unless you bought wheels with a custom offset or you went with Z06 wheels. But putting spacers on them would make them stick out farther. I have 19's on mine and had to use spacers to clear them. I should have got the brakes first then ordered my wheels and I wouldn't have to use them.
The offset on the front is 57mm and the rear is 44mm. I know on the front I have a 1/2 inch spacer, I forget on the rear, I believe it is 5/8. You also would have to put on longer wheel studs. The wheels are 19x10 on the front and 19x11 on the rear. Hope that helps.
