Replacing 1 Valve spring
Old 07-03-2011, 06:14 PM
Lawhead's Avatar
Default Replacing 1 Valve spring
Well one broke today after my tranny swap. There is only one broke bought the motor used so not 100% sure what brand they are say I get on that is good for the lift of the 306 does it matter if it is a different brand then the others? will this hurt anything
Old 07-03-2011, 06:26 PM
speed_demon24's Avatar
So you don't care that the other 15 might be close behind in breaking? Valvesprings don't last 200k on cammed motors like the stockers do... they are a maintenance item.
Old 07-03-2011, 06:33 PM
Lawhead's Avatar
Motor is recently rebuilt so figured all the rest were fine this was just a freak thing
Old 07-03-2011, 06:35 PM
tbag_skywalker's Avatar
I'd be uneasy about replacing just one spring unless I knew exactly what brand that and the other 15 are. Like speed_demon said, the other 15 could be on their way out, too.
You don't have to spend big bucks to get a good set of springs. I picked up Patriot Gold double springs with seats, seals, locks, and retainers for around $260, and they're good for a .650" lift.
Old 07-03-2011, 06:36 PM
bigj2717's Avatar
If you're going to do it do it right and replace them all so you know they are all good.
Old 07-03-2011, 06:37 PM
Lawhead's Avatar
Looks like the car will be down for another few weeks then
Old 07-03-2011, 06:54 PM
Puck's Avatar
You cannot match the proper open and closed pressures and install height without knowing what the rest of the springs are.
A spring for your modest setup would be relatively cheap - just get a full kit, change them all, and have piece of mind that the job was done right .
Old 07-03-2011, 07:09 PM
Lawhead's Avatar
Yeah it just sucks all the time for the tranny swap and this just happens it kinda urks me lol. Now that this happened thinking about going with a NSA package with the 1.6/1.7 split I was talking about doing see how that goes
Old 07-03-2011, 08:45 PM
flame's Avatar
You've got about a 99% chance that the valve hit the piston when the spring broke and bent the valve. How's the pushrod look?
Old 07-03-2011, 08:55 PM
trilkb's Avatar
Thunderracing tends to have alot of 10% off sales and they have patriots. The 8401's are what i have so im sure they would work well for you too. I think they were like 230$ after the 10% off.
The 8501's im sure are overkill for your application.
If your install height is 1.750 then the 8401's should be good. Thats if you want patriots. If you want the beehives then the Pacs that everyone else gets would be fine im sure.
Old 07-03-2011, 09:11 PM
joelster's Avatar
I'm gonna guess and say you broke a 918 beehive from Comp.
Old 07-03-2011, 09:14 PM
Lawhead's Avatar
the spring didn't totally break push rod was fine
Old 07-03-2011, 10:48 PM
SoxXpupPeT's Avatar
id Never change just 1 valve spring.. But thats just me. Its cheap enough for a full patriot gold spring kit to just replace all 16 sets and be done with.
Old 07-04-2011, 08:58 AM
Lawhead's Avatar
Yeah I suppose
Just sucks having it right here almost done after swapping a tranny then it just happened to do that.
Old 07-04-2011, 10:11 AM
Village Troll
SS RRR's Avatar
Thumbs up
Originally Posted by Lawhead
Yeah I suppose
You are going to find that when trying to maintain a modified engine you'll run into the "it just happened to do that..." here and there.
Hopefully it's nothing more than the brand of spring you used.
Old 07-04-2011, 03:02 PM
Lawhead's Avatar
Yeah trying to get a hold of the builder of the motor to see what was used probably go with the Patriot kit though for it and be done with it
Quick Reply: Replacing 1 Valve spring
