GTO Ignition Key Resistor Values- Anyone?
Does anyone know what the range of resistor values are for the 2004 GTO ignition keys?? I have a 2004 GTO eng/trans with all stock wiring in place, including the original BCM and PIM. Before junking the donor car, I measured the resistance in the key and wrote it down.
Now with the engine hooked up and ready to go, I'm getting a start and immediately die situation. That symptom is the same with the BCM connected or not. So I'm thinking that points to the anti-theft portion of the BCM. I've wired in a resistor of the same value as the key I had, but am wondering now if I got the value wrong. So if anyone has a list of what the range of values might be, I could check mine against it.
Anyone have that info?
Thanks
Andrew
Thanks
Andrew
you might want to try posting this up on LS1gto.com. Sorry I can't help but sure would like to know the answer too.
With some further reading 200K for resistance but the little nub on the GTO key is a path way for a signal from the BCM to retrive a code built into the key fob. If the code is not correct you will not be able to start the car.
Maybe this link will help
http://www.ls1gto.com/forums/showthr...remote+battery
http://www.ls1gto.com/forums/showthr...ote+resistance
You may have measured resistance but it wasn't a resistor. There is a programmed chip in it that has to have the nub on the key complete the circuit with the ring around the key hole. It's an anti-theft code on the chip and the symptoms you have are exactly what you get when the key turns but the computer is not getting the right code. I hope you have the original key or you'll have to buy an expensive fresh one (an old one can't be reprogrammed) and program it to the BCM.
the key.............
Interesting info on the key. I was wondering about that too. But the factory shop manual labels those (mechanical) connections to the key as "resistance". The wiring diagram for the BCM labels it that way as well. I understood the circuitry inside the key was for the remote entry only. What's interesting is the PCM is not giving off a theft deterrent fault code.......
I'll have to check into this further.
Thanks
Andrew
Thanks
Andrew
