School me on Keyless entry.
It will have a LED on the top cover of the dashboard, right between the grille/vent on it. There will also be a sensor on the back, by the antenna/spare. These are two key parts that will help you identify if it has a factory alarm. If it does, just get yourself a remote, program it and bingo!
Ungrounded Moderator
Try this:
1. Turn the ignition to RUN (do not start engine) then back to OFF
2. Remove the RADIO fuse.
3. Turn the ignition from OFF to RUN three times quickly (within five seconds).
If you have keyless entry and could program new remotes, the car will respond by locking the doors, unlocking the driver's door, and popping the hatch. If it does, buy yourself a new key fob from the dealer or ebay and program it. If it doesn't respond, you'll have to look at aftermarket kits.
In any case, turn the ignition OFF and replace the RADIO fuse to exit remote matching mode.
