LCA Relocation Brackets
my question is... there are 3 postitions on the relocation bracket and i want to know what position to use. there is stock, middle and closest to the ground. my car is dropped 1.25".
any thought would help, i just dont want to keep moving it around and my car does not hook anyway, need DRs.
LS1Tech Premium Sponsor
Definitely use the lowest hole since your car is lowered. It looks like you may be planning one day to make a bunch of power and when that time comes you may want to move irt up a hole but for now keep it in the lowest.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
They allow to tune in the "instant center" of the chassis, helps to properly align the suspension after lowering the car.
They helped to eliminate my wheel hop... just saying..they are worth the money.
Not only does it do everything that Meine96ws6 said but it also adds positive anti-squat to the car which helps keep pressure on the rear tire and in turn really helps with traction. The lower control arm relocation brackets are definitely worth the money to do.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
If you have a 10 bolt you are honestly on borrowed time anyways because at some point in time it IS going to break. I know here locally we had quite a few cars run low 10's on them with the good majority of them being automatic cars which are much nicer on the rear ends then the 6 speeds are. Like you guys have already said getting the suspension dialed in and getting rid of the wheel hop will definitely help with the longevity of your 10 bolt and the lower control arm relocation brackets is one of those parts that will really help.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
