If i get longtube headers will i have replace gaskets all the time
Old 08-01-2011, 09:31 PM
MYLSWON-ws6's Avatar
Default If i get longtube headers will i have replace gaskets all the time
I want longtube headers for the horsepower but im not very good mechanically . Will i have to keep replacing the gaskets on the headers if i get them installed professionally???????
Old 08-01-2011, 09:36 PM
TankTheTurtle's Avatar
You should never have to "keep replacing the gaskets"
Buy good ones, install them with the new headers and don't worry about it again..
Old 08-01-2011, 10:00 PM
Does the headers come with gaskets. And what kind of headers should i get
Old 08-01-2011, 10:14 PM
my bandit's Avatar
alot of people get the stock ones since they are multi layered and metal instead of the cheap paper
Old 08-01-2011, 10:16 PM
+badss+'s Avatar
when i got my tsp headers i got new gm gaskets with it, id stay with the gm ones.
Old 08-01-2011, 10:17 PM
babbage1109's Avatar
Get whatever headers you are comfortable paying for. 1 7/8 will give you more gains than 1 3/4 but theyre all basically the same. Just whatever you want to pay for
Old 08-01-2011, 10:18 PM
Mumbles's Avatar
Depending on what kind of shape they're in, you could reuse the original factory multilayer gaskets.
I only had like 46k on my Firebird when I installed LTs. I went ahead and replaced mine with some new Factory Manifold Gaskets, but my originals would have been fine.
Either way, don't use the Gaskets that are supplied with the Headers, otherwise you will be replacing them "all the time". Head to the local dealership and lay down $30 (or whatever they cost) for a set of new gaskets. Then during disassembly, inspect yours and decide whether or not you can reuse or replace them. If you reuse, then simply return the gaskets and get your money back.
Also, be sure you look into upgrading your Motor Mounts, while you have the Factory Manifolds off the car. There is no better time to bite the bullet and get this done. Good luck.
Old 08-01-2011, 10:19 PM
Tyler Z28's Avatar
+1 stick with GM gaskets.
Old 08-01-2011, 11:05 PM
Sales1@Texas-speed's Avatar
Yep put the GM gaskets on and you should be good to go for a long time!
Old 08-02-2011, 12:40 AM
LS6427's Avatar
Gaskets should be purchased once, they don't need replacing. My first set on my 427ci lasted 4 years and looked fine when I had to remove my heads for a rebuild. I think I paid $16.00 if I remember right for regular GM replacement gaskets, been fine since 2006.
Old 08-02-2011, 01:22 AM
sixvi6-camaro's Avatar
+1 on GM gaskets. Also for the first couple months after the install check the header bolts just to be sure none of them are backing out. After that they should be good.
Quick Reply: If i get longtube headers will i have replace gaskets all the time
