If i get longtube headers will i have replace gaskets all the time
I want longtube headers for the horsepower but im not very good mechanically . Will i have to keep replacing the gaskets on the headers if i get them installed professionally???????
Depending on what kind of shape they're in, you could reuse the original factory multilayer gaskets.
I only had like 46k on my Firebird when I installed LTs. I went ahead and replaced mine with some new Factory Manifold Gaskets, but my originals would have been fine.
Either way, don't use the Gaskets that are supplied with the Headers, otherwise you will be replacing them "all the time". Head to the local dealership and lay down $30 (or whatever they cost) for a set of new gaskets. Then during disassembly, inspect yours and decide whether or not you can reuse or replace them. If you reuse, then simply return the gaskets and get your money back.
Also, be sure you look into upgrading your Motor Mounts, while you have the Factory Manifolds off the car. There is no better time to bite the bullet and get this done. Good luck.
