no compression?
no compression?
I have an ls1 nd just finished putting the motor together nd ran a compression test nd I am getting all 0's where can I start nd what can I do to find the problem and or reason behind this
Yea zero compression new gaskets nd bolts for everything on a stand finishing thing nd checking before I put it in the car no rags any wear timing chain on in time I'm lost as. All get out
What ever happened with this? I'm getting zeros across the board as well. Gauge works, so that 's not it. Did a cam swap- bought cam, springs and push rods as a package from EPS- so I'd think they would be right. ? Going to pull a rocker arm off one and see if that makes a difference.
If all the pushrods were too long, would that cause what I am seeing?
