T56 Maintenance.
Old 09-27-2011, 01:55 PM
stephen4036's Avatar
Default T56 Maintenance.
first time owning a T56, was wondering what fluid, how much, and if any TSB is out for it.. was also wondering how often you all change the fluid in your T56 as well..
thanks in advance.
Old 09-27-2011, 02:05 PM
JohnS Z28's Avatar
would also like to know this..bought mine last month and would like it to last.
Old 09-27-2011, 03:55 PM
pewter2002's Avatar
https://ls1tech.com/forums/manual-tr...ion-fluid.html This is what I've heard, and use conventional oil, not synthetic.
Old 09-27-2011, 04:03 PM
Blwn_by_Twins's Avatar
You don't even need to use the search button. Just looking the the threads made in the last few days and you can find all the info you need. Or look in the FAQ section. It does get old seeing the same thing asked 3 times a week though.
Old 09-27-2011, 05:45 PM
BALLSS's Avatar
dexron 3, 4qts
the material in some of the T56 parts don't like synthetic
with that said people run just about anything in them
My $02 is follow the manufacturers advice...the sticker is on the DS of the T56
Old 09-27-2011, 06:43 PM
777's Avatar
Fry, cool it or you'll be getting a timeout. If you can't post something constructive/helpful then don't post.
Old 09-27-2011, 07:08 PM
my friend said he runs 4qts of mobil 1 5w30 in his t56 and its help up great.. anyone else do the same?
Old 09-29-2011, 10:43 PM
The Scammer Hammer
dr_whigham's Avatar
Pleased don't post **** like this.
Let me rephrase, as maybe you didn't know yourself... Please don't anyone FOLLOW that advice.
Old 10-01-2011, 10:46 PM
mlatorre's Avatar
thanks in advance.
Change the oil yearly with 4 qts of Dextron III normal use, more often if abused. Do-not use synthetic trans fluid unless you have changed all the paper syncronizer pads to carbon fiber or they will self-destruct. Also the fork shift pads and shifter fulcrum should be changed over to Bronze from the factory plastic. the extreemly powerful detergents in synthetic tend to degrade the plastic over time.
Hope this helps,
mlatorre
Old 10-01-2011, 11:50 PM
Hope this helps,
mlatorre
gotcha, yeah ill run dexIII, my T56 is leaking from somewhere but I cant find it :/ its not from the top, the side are dry.. all the sensors seems to be dry.. not sure what else it could be.
Old 10-02-2011, 10:18 AM
RedRallyeZ's Avatar
check the rear seal, I'm pretty sure thats where my leak is coming from. Those can rot out after awhile.
Old 10-02-2011, 10:20 AM
by rear seal do you mean the tailshaft seal? or the seal that connects the shifter body to the main body?
Old 10-02-2011, 01:23 PM
RedRallyeZ's Avatar
Both are worth checking when you see a leak, but i was referring to the tailshaft seal. I just used a bead of RTV around my shifter, I think that is the preferred method on the forum.
Quick Reply: T56 Maintenance.
