Turbo build
ASSuming On The Tree
Turbo build
So I am planning on building a budget turbo on my for-now stock LS1, running low boost until I get forged internals and 317 heads.
I would like to build a twin turbo, and I was thinking of using twin Holset hx35 turbos. Do you think the stock displacement is enough, or will their be significant turbo lag?
Also, I have read that buying the hx35w and bypassing the wastegate is a possible option, as it has a 12cm housing, vs 16 for the non-wastegate.
Is this feasible?
Is this feasible?
It's in a 04 GTO. Stock engine internals. I am still deciding between the 243 ported heads I have, or 317 heads.
My question is if it will work well for a street car, as in not having terrible turbo lag, or if they're too small and will run out of steam quickly.
Really can't say without knowing which turbo kit it is and more about those turbos. Your housings, piping, and turbo placement are going to determine if it will lag or run out of steam.
Is this a system you are building? Have you built a turbo system before?
http://www.ebay.com/itm/CUMMINS-HX35...-/170722809040
That's the turbo I've been looking at.
And I haven't built a turbo system before, this is my first time. But I'm going to only tack everything up, then have a shop weld it up.
Location: Home town Clive,IA current town FORT BENNING GEORGIA
Yeah man I actually found my kit on here for sale. Just make sure you have a very open minded budget because i originally had 5k budget.... broke that about the 4th month i started...
