What mod to do NEXT??Opinions!!!
Thanks ssfiress:
I install the ASP Pulley last week and i felt the diference.
The times in the sing was without the pulley.
I want to keep out of the motor until i get the best times with just only bolt ons with naturally aspired motor..
My next step going to be 8.8 rear and a set of 26 X 10 slicks to see if i can go deep in the 1.7 or 1.6s 60 foot.
You tnink is posible to hit higth 11s with just bolt ons?
That's a lot of money for not going into the motor yet.
I'd :
1) Fix traction issues. Check your LCA angle. The arms shoud be parallel to ground if not uplsoped to front of car. Change to aftermarket or buy relocation brackets. Pull the front swaybar at track. Run at least a stiffer torque arm
2) Then go for a cam/valve springs. Not a hard swap really and
best bang for the hp
I'd :
Sunset01 you think i have a mayor traction issue?
To very if my lca angle is rigth ,i have meassure both end of the lca's in relation to a flat floor surfes?
My car is not lowered even the relocator bracket is a good investment for me?
What you all think ,i need a biger throtlebody?
The Shanner S2 is a good piece?
Thanks
Thanks
Maybe that was a bit presumptuous about your traction, but I would have thought you could 1.8s in the 60'... guess it depends how hard you are launching, whether you are getting any wheelhop.
Just look at your lower control arms on a flat surface compared to the ground. My car isn't lowered and they point slightly down to the front, which is the wrong way...
I've heard good things about Jantzer's throttle body, not sure if it's worth it until you have a cam...
The best i does was 2.011 60'.I tried every possible way to luanch it.From idle to 4k rpms,from 35psi tire pressure to 14psi.The car not do any wheelhop it sit the back hard but not hook hard enoth to break in the 1.9s.
What you think about Hal shocks?It worth the price tag in my case?
Are you heating your Nittos up? I pulled consistent 1.8s with my Nittos and very similar mods that you have (didn't have my headers, torque arm or ported TB last time I raced). Make sure you at least heat the Nittos up for a couple of seconds, then launch at somewhere around 2.2k-2.5k rpms. That's what I did and it seemed to work...
Originally Posted by fastsspr
I not have any suspention tricks except BMR tubular LCAs.How much you think i can help my car at the track if i invest in suspetion parts?
