Valvetrain tick???
Old 11-18-2011, 05:14 PM
CorySS's Avatar
Default Valvetrain tick???
I just replaced my lifters and now I have a tick from the valves. I double checked the valves when I tq them down. And now when it warms up it starts to tick loud, but it only does it after it's warmed up. Any ideas or input as to what it might be?
Old 11-18-2011, 07:17 PM
crainholio's Avatar
There's more info waiting to be posted...what cam are you running, and what lifters did you install?
Old 11-18-2011, 07:46 PM
CorySS's Avatar
Stock lifters, and a comp cam .617/.620 lift
Old 11-18-2011, 07:48 PM
CorySS's Avatar
I'm sorry LS7 lifters
Old 11-18-2011, 07:50 PM
crainholio's Avatar
Originally Posted by CorySS
LS7 lifters, and a comp cam .617/.620 lift
Got it, and what pushrods (length) are you running?
Old 11-18-2011, 09:19 PM
CorySS's Avatar
Stock leight comp cams
Old 11-19-2011, 04:54 AM
crainholio's Avatar
Those are likely your problem. The taller cam has a shorter base circle, which must be accommodated via longer pushrods or adjustable rockers.
Do some reading here on pushrod length measurement and give it a shot.
Old 11-19-2011, 09:43 AM
CorySS's Avatar
That's what my buddy said that it might be. But if it was push rod leight wouldn't it do it as soon as it started and not after it warms up? I was looking around by the header and couldn't see anywhere where it looked like it was leaking.
Old 11-19-2011, 10:58 AM
crainholio's Avatar
Consider how a hydraulic lifter works by using engine oil to create hydraulic pressure on the lifter's plunger. The oil thins as it gets up to operating temperature, enabling the plunger to bleed down faster during lobe lift. This creates lash and accompanying noise, if the plunger isn't held at optimum depth by the pushrod.
Get a $20 Comp measuring tool and you'll find what you need.
Old 11-19-2011, 06:07 PM
CorySS's Avatar
Well that makes a lot more sense, thanks
