Will this combo make decent power ?
I am putting together a 5.3 with a stock lower end and have already bought a few parts for it , now I am thinking I want to add a turbo to the project . I have a stock 5.3 motor complete , a carb intake , a MSD 6010 , a Comp xer287hr cam , and a set of 241 heads that have been ported . I am looking at adding a turbo and using the 241 heads and the Comp cam , I have been told I need a 70-76mm turbo for the 5.3 . I found this one on Ebay fairly cheap -
www.NOT-A-SPONSOR.com.org.gov.net.edu
Will this combo work , or do I need to do something different ?
Oh yeah , on pump gas and without a intercooler ?
For $500 you can do better. That's only a P trim unit. Small turbine. I'd look into a used Precision 76 or a Turbonetics 76. It will cost a touch more but will have a larger turbine. Plus the peace of mind of a name brand turbo.
If you're stuck at $500, pick up a MasterPower turbo.
Ok , I will check into that , thanks . If anyone knows of a good deal on a used turbo , I would be interested . But , I would still like to know if this is a decent combo ? Should I get rid of the cam and get something turbo specific ?
Here is a link to the cam specs - http://www.compcams.com/Company/CC/c...csid=1094&sb=0
I am hoping to run pump gas in it , and will be keeping the boost moderate .
