Custom EPS Cam + 243 build. Look inside
Old 02-05-2012, 07:37 PM
gregrob's Avatar
Default Custom EPS Cam + 243 build. Look inside
Custom EPS Cam already have it
Stock rockers with trunion upgrade
243 heads, possibly AI ported, or hand ported by Chad Speier
LS3 hollow int valves
PSI Xceldyne Springs
Lashway Pushrods
C5R Timing Chain
Ported LS6 Oil Pump
Thinner MLS head gaskets
Springs, undecided. I want lightweight but I'm kind of gun shy on beehives... Maybe PSI Beehives.. or I may stick with trusty PRC Dual Gold Xtremes...
LS6 Intake already have
LS6 Valley Cover
LS2 Lifter Trays
??? throttle body
SLP 85mm MAF already have
FTP 95mm? airlid
Chrs1313 Ram Air, A/C version
Ace Racing Stg2 Trans - already have
FTI 3800 stall...
Nitto DR's on Heavy Z06 replicas for now.
150 shot on occasion
Comments, suggestions, part numbers?
Old 02-05-2012, 07:57 PM
RonSSNova's Avatar
Cam specs a secret?
Old 02-05-2012, 09:10 PM
A.R. Shale Targa's Avatar
Definitely have AI port them 243s and pop some Lunati Gold duals on em'.
I'm geussing your cam is about 230/234 and should make some real nice
power.
Old 02-05-2012, 09:55 PM
gregrob's Avatar
I will PM cam specs but its a grind I came up with and found out Geoff had already done it before with great success.
I'll just say this, I'm definitely a fan of baby cams
Old 02-06-2012, 12:13 AM
RonSSNova's Avatar
I'll show you mine if you show me yours.
That sounds really bad......
PM sent. I wanted a small cam as well.
Ron
Old 02-06-2012, 06:20 PM
garygnu's Avatar
if it ain't too big of lift some pac1508 should work .
Old 02-06-2012, 06:34 PM
mac62989's Avatar
Come on you can tell us, I wont tell anyone
Old 02-07-2012, 10:17 AM
A_VAS's Avatar
Chad must be a magician if he can put a 2.165 valve in a 243 head ?
Old 02-07-2012, 10:51 AM
Fbodyjunkie06's Avatar
PSI springs are great as are the nextek by manley.
Old 02-07-2012, 11:00 AM
PREDATOR-Z's Avatar
That is probably on the exhaust side intake needs bigger
Old 02-25-2012, 03:44 AM
gregrob's Avatar
Well this has taken a little different turn since I want to focus on my race car instead of wasting more money on my DD...
Anyway, here are the parts I've purchased, am I missing anything? My brain isnt working tonight...
Head Gaskets
Head Bolts
GM Water Pump Gaskets
Fel Pro Intake Gaskets
GM Timing Cover Seal
GM Front Seal
GM Harmonic Balancer Bolt
GM HD LS2 Timing Set
Pac 1218 Springs
Trickflow 7.425 pushrods
Plus the heads, cam, etc...
Old 02-25-2012, 03:46 AM
gregrob's Avatar
Also with 108K on the car would you guys throw new lifters in it?
It's got a little tick sometimes but I'm almost sure its an exhaust leak.
Old 02-25-2012, 03:50 AM
Blackbird-WS6's Avatar
get a new set of ls7 lifters
Should always replace your lifters when swaping a cam
Might need bigger injectors and fuel pump to go with that 150shot
Old 02-25-2012, 03:56 AM
gregrob's Avatar
I have a walbro 340 and hotwire harness ready to drop in as well. Stock injectors should be fine..... You dont need to increase injector size with a wet shot. I'm sure at my altitude the stockers can fuel the engine with the baby cam and stock 243s...
Old 02-25-2012, 08:21 PM
TXZ28LS1's Avatar
what about the tranny...LOL...
Sounds like a solid build my friend!!!
Old 02-25-2012, 10:55 PM
Mike Morris's Avatar
You will need injectors!!!!!!!!
Old 02-25-2012, 11:44 PM
gregrob's Avatar
Dude my truck is still in the shop or I would have been over to get it! Im gonna kill the guy who is supposed to be fixing it...
I will def come pick it up when I get home here in a week tho!
I'm gonna run the stock one til it ***** out, then order up an FTI 3800 stall to throw in front of your old trans.
Old 02-25-2012, 11:46 PM
gregrob's Avatar
I doubt it, at my elevation... but I hope I'm moving enough air to need them! I would like to be proven wrong.
Old 02-27-2012, 12:09 AM
gregrob's Avatar
Just ordered SLP underdrive balancer, DMH cutout, Lunati dual gold valve springs
Old 02-27-2012, 12:25 AM
crazyelf's Avatar
These are often over looked when doing heads and cam sometimes cause a small leak if not replaced
12551933 this is a small gasket used on the coolant cross over or block off
12602541 cross over o-ring used in conjunction with gasket above
Ive pulled some off with both being used and some with just one or the other....GM must be very inconsistent or someone else was there before me. You need 4 of each part number, they're cheap anyways.
Quick Reply: Custom EPS Cam + 243 build. Look inside
