Stock rear, how much can it take??
Ok, I have a 1981 Turbo TA, and installed a LQ4, and GT45, It started whining, and I had a guy (rebuild) it, any way it started whining even worst, then he tells me he didnt change the gears cause I wanted the same gear ratio! Do I spend another $500 for new gears, and labor, or do I need to get a whole new setup? The gear is 3.08s, in a 8.5, he installed a new posi unit, bearing, and seals. Will the rear take the abuse?
heeeeell no. do not put any money in that thing. its prob whining because its leaking. get up under it and see if you have any fluid on your torque arm bolts. if so fill her up or have the pinion seal changed at the dealer for like 200 and be easy on it....do not ever build up a 10 bolt...put that money towards a 9 and dont ever worry about it again...the 10 bolt is a weak piece of **** that has been known to have problems even at stock power levels....much less a turbo lq4. im not sure this belong in the forced induction section though.
Op, rebuild it with good gears, c clip eliminators and weld the tubes and you will never hurt it.
the rear is fine, best gears you can get is factory GM gears they are cheap and set up nice., run a set of moser axles and it will be fine....GN guys are running in the 9's with them.
