Who does the best porting for heads?
Old 05-17-2012, 04:02 PM
needtransam's Avatar
Default Who does the best porting for heads?
Who does the best porting for heads and prices?
Old 05-17-2012, 04:19 PM
Grimes's Avatar
are we talking value here or all out no expenses spared? baller money = afr heads with tony mamo doing hamd porting on them
Old 05-17-2012, 04:20 PM
Cosmos's Avatar
Use the search feature. Many threads on prices and results. AI is the current budget favorite here on tech.
Old 05-17-2012, 04:24 PM
yes i looked at AI but not sure if they exist call them and nothing and Im talking best for the price
Old 05-17-2012, 04:41 PM
Turd Gen Guy
1nasty86's Avatar
Total engine airflow does good work also
Old 05-17-2012, 05:10 PM
Camaroking1996's Avatar
http://advancedinduction.com/
Yes they exist and do some of the best porting around.
Old 05-17-2012, 05:36 PM
Darion's Avatar
I'll second that! Get ahold of Mike and he will make sure you get what ya need for your application.
Darion
Old 05-17-2012, 05:46 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Give us a shout. We have numerous options available for porting your heads or we can get you into new castings for very reasonable prices and performance on par or better than our competitors' offerings.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 05-17-2012, 06:01 PM
badazz81z28's Avatar
I would tend to disagree there.....
I did alot of research on this subject a few months ago. AI is one of the most expensive porting options out there for stock heads. A set of their heads will run you into the $2K arena. TEA is about the same. Of course there are bigger names out there is about the same price range.
I know you have heard or seen this alot, but you really cant beat Texas Speed Perf's PRC heads.
You can get complete CNC ported heads with bigger SS valves and springs for around $1500
Labor and Upgraded parts to your existing heads is what $1500 will get you from the other known names and you supply the castings.
Very subjective on who's heads flow better, like expected the guys who payed more for their work will say theres are the best.
My advice would be to get a budget and go from there.
Old 05-17-2012, 06:04 PM
AI is $1200 for the porting including springs. The $2000 is a cam and head porting package which includes everything you will need for the heads and cam swap.
Old 05-17-2012, 06:09 PM
That does depend on the option. Are you referring to their full CNC or basic rebuild?
Full CNC is $1000
Which they are not giving you new spring, valves, retainers etc.
Add that all in and your looking at $1500, not to mention if your cores need some addtional work.
Old 05-17-2012, 06:43 PM
Turd Gen Guy
1nasty86's Avatar
Or.... You could buy a prc ls6 head and not worry about a core charge or waiting to get them back...
Old 05-17-2012, 07:16 PM
Captain Double Post
BOBS99SS's Avatar
I would just go with the prc ls6 heads, there a steal for what they are, the only way i would pay to have any heads done at ai is if i got a set of 243 under 300 bucks, tsp hands down imo, less hassle and they can have everything ready to go so when the get to your door you can just slap them on
Old 05-18-2012, 10:05 AM
Rise of the Phoenix's Avatar
Ed Curtis at Flowtech Induction. He's not a sponsor, so I can't post his prices, but for under $1,500 you get fully ported 243/799 heads that come complete with springs, retainers, etc. Basically, all you need to bolt on and go. His work speaks for itself.
Old 05-18-2012, 10:22 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I think the proper way it needs to be states is "Who does the best porting for heads that I can afford?"
Then the real question is "How much money do you have?"
All depends on budget and what your planning on doing. Personally would not sink any money on Small Bore heads. When I get a LS2 or better block "See 4.000" Bore. Then you spend money. Also IF you needed to sell you have something people may want.
Just IMO.
Old 05-18-2012, 10:57 AM
Just IMO.
Subjective, My LS1 is brand new so investing in my small bore engine/heads is worth it as it will be under my hood for a while.
Old 05-18-2012, 11:54 AM
5 Liter Eater's Avatar
Interesting thread. I've been looking at some ported 317's or aftermarket. Patriot's seem hard to beat for the price. TSP PRC's are slightly more expensive and flow similarly. AI seems expensive and you have to send your heads off, considering I could get the first two without a core charge and sell my existing heads. I kind of question the exhaust flow on the AI's. Their 232cc job says they flow 274 @ .600" which is way above even the TFS/AFRs.
Old 05-18-2012, 11:56 AM
Those exhaust numbers would have to be with a pipe....which is just one of many variables that make it very difficult to compare heads online.
__________________
Old 05-18-2012, 12:23 PM
98ws6blk's Avatar
What about Patriot Performance for the budget inclined?
Old 05-18-2012, 12:27 PM
Internet Mechanic
Your absolutely right that it is subjective but building a short block and I have done it a few times that the cost difference is minor to go bigger once you go to a LS2 block or better. LS1 need re sleeving which for most its easier to just go LS2+ So If I spent major money now and may or may not see a worthwhile gain to make it worth the time.
If I really wanted a set of the heads for the street cam I have (228/230 @112) I would go look for a used set and pay as little as I can, upon successful inspection, set it up for new springs and go.
Like said subjective and your point is just as valid, it all depends on what someone is willing to spend.
I half think about a max effort stock cube cam, or heads, or 150 shot... plenty of options.
Quick Reply: Who does the best porting for heads?
