T400 guys here
T400 guys here
Thinking about putting a turbo400 in my '94. what would i all need to make it work besides the obvious trans mount, driveshaft, and torque arm? will my stock starter work?
Originally Posted by RamAir95TA
Posted from LS1Tech.com App for Android
If you want the speedo to work you will need to pick up a reluctor and a pick up. You will need to tweak your cooler lines or make new ones. Are you going to put a shield on it?
What are you building that you want a TH400?
A 4l60 can hold a ton of power when built right, plus the OD makes it easy to cruise in without screaming down the highway at high RPMs.
I actually just did the swap but havnt driven the car yet still more work to do. You will need the correct Flex Plate, Torque Converter, Cooler lines, Dip Stick Tube, Driveshaft Length adjusted, Tranny Crossmember, TA Mount, Shifter.
The swap is super easy to do! I havent monkeyed with the Speedo stuff yet but I did install a Gear Vendors Overdrive unit! My TH400 has a Trans Brake and RMVB too!
Joe
Joe
