Borg Warner S480 Turbo L33 5.3 1991 Mustang Notch build update 3/27
Old 07-04-2012, 02:29 PM
Sarg's Avatar
Default Borg Warner S480 Turbo L33 5.3 1991 Mustang Notch build update 4/13/14
Figured I would start a thread on this. I am hoping that it will move pretty fast once I get the title for the car. Guy should have it to me next week and I am waiting to put anything IN the car till I have the title in my name. But I will update as I go.
The plan right now is to have this up and running in the next couple months. At this point I have most of the parts I need. The rest I will order as more information becomes available. My plan is to have a streetable car that will weigh in pretty low and still be a fun track car. I plan on having all the safety gear to take it into the high 8's and still be able to drive it home at the end of the night.
I had to ditch my WRX build due to some issues and this was the best car to finish the ls build. Everything will pretty much bolt into this car. All I should have to fab to get it running are some misc mounts and the turbo kit.
Engine:
-L33 5.3 with stock short block and upgraded ARP rod bolts
-ARP studs
-Lunati off the shelf cam
-Holley Hi-Ram intake manifold for cathedral port heads
-Dual valve springs and Ti retainers
-double roller chain
-Comp pushrods
-C5 accessory drive
-Custom harness
-Trunion upgrade
-Gotta make the turbo kit
-A2W intercooler
-Borg Warner/ Forced Inductions S480 turbo
-Manifolds to be determined, but hopefully my C6 manifolds will work out
Fuel:
-BD racing fuel cell
-160lb Bosch injectors
-Aeromotive Eliminator fuel pump
-Hard line to fuel line to be determined
Trans and drivetrain:
-Jake's Performance 4L80E Stage 2
-Circle D converter
-Custom Kilduff Shifter
-8.8 rear end with 3.27
Misc:
-Wolfe 10 point weld in cage
-ADR wheels
-HP tuners 3 bar tune I will be doing myself
-AGX wideband
-PLX boost and intake air temp gauge (will add more sensor modules)
-several new interior pieces
-seats to be determined
-audio to be determined
Day it came home:
Wife helping out:
Cage is done!
Motor in:
Accessories going on:
She lives!! Not sure exactly how to imbed...but if you click on the pic it works.
Old 07-04-2012, 02:34 PM
94'BLKBRD's Avatar
What size turbo are you going to run?
Old 07-04-2012, 02:48 PM
Sarg's Avatar
80mm T6 S480. I will update the thread quite a bit here this evening. On my way out the door right now for a cook out.
Old 07-04-2012, 03:06 PM
Freeman83's Avatar
About time you started this! Already subscribed. This will be an awesome build. Gotta love big power.
Old 07-04-2012, 03:48 PM
Tuckin15s's Avatar
Sub'd can't wait to see more!
Old 07-04-2012, 06:09 PM
LILHEMI's Avatar
Subd for ***** n giggles
Old 07-04-2012, 06:43 PM
slo89lx's Avatar
can't wait to see the out come
Old 07-04-2012, 09:38 PM
Sarg's Avatar
OK, got a little more background info in the first post.
Old 07-04-2012, 09:46 PM
bigpapi211's Avatar
Tuned in on this one..
Old 07-06-2012, 10:17 AM
Sarg's Avatar
Kilduff shifter ordered. It is the autostick with some custom bits and reverse lockout added. I am pretty excited about the shifter and can't wait to see how well it works.
I also have the front suspension, subframe connectors, torque box reinforcement and front 10 way adjustable struts ordered.
Old 07-07-2012, 04:12 AM
philsblwnz28's Avatar
subs... doing the same build with same turbo, after I find a roller notch.......
Old 07-07-2012, 06:36 AM
Sarg's Avatar
Cool, well I will let you know how the qa1 k member with the upr conversion mounts goes hopefully this week.
Old 07-07-2012, 07:33 AM
96lt4c4's Avatar
I think its funny how everyone on this site accepts the chevy engine going into a Ford. I think its great myself. Hell I would love to have a little Fox with an LS in it. My local Mustang friends just can not get past the idea that in order to make a Mustang fast you need to put a Chevy motor in it
Old 07-08-2012, 10:05 AM
Sarg's Avatar
I would much rather have a nice ls motor than those old 5.0 motors any day of the week.
Well, since it was a 4 cylinder, the 5 lug conversion was a snap. I still need to get some new bearings I believe, but here is the new pics.
Old 07-08-2012, 10:38 AM
STight's Avatar
Default subscribed
let the fun begin...
Old 07-08-2012, 11:45 AM
Sarg's Avatar
first new part!
Old 07-09-2012, 09:44 AM
Tuckin15s's Avatar
Can't wait to see what you do with it sarg.
Old 07-09-2012, 04:12 PM
Sarg's Avatar
Hopefully stuff should start arriving here any day. I am waiting on a couple key parts to really start the build.
Old 07-10-2012, 11:54 AM
1bad03snake's Avatar
If your C6 manifolds dont work and you use truck manifolds. Wanna make me a merger pipe?
Old 07-10-2012, 12:16 PM
Sarg's Avatar
Only if you have the exact same set up. I will be using vette accessory drive set up, manifolds to be determined.
Quick Reply: Borg Warner S480 Turbo L33 5.3 1991 Mustang Notch build update 3/27
