low rpm/ light throttle surging
Old 08-11-2012, 04:04 PM
Cam99's Avatar
Default low rpm/ light throttle surging
Was told to post this here also
https://ls1tech.com/forums/generatio...l#post16612505
Old 08-11-2012, 07:21 PM
BLK02WS6's Avatar
Do you know if it is running in open loop or closed loop? Can you post up the tune?
Old 08-11-2012, 08:06 PM
Cam99's Avatar
It doesn't seem to do it when it first starts up ( I can never remember if that's open or closed loop). I'm not sure what you mean by posting the tune up. It's the stock tune as far as I know, or what it was when I got it, with 3 degrees pulled out from 3000-6000rpm at WOT for the spray with a predator
Old 08-11-2012, 08:10 PM
BLK02WS6's Avatar
Well, if it has a cam in it and running on the stock tune, there's your problem... It needs tuned.
Old 08-11-2012, 08:26 PM
Cam99's Avatar
The one with the problem is the 99 Camaro. Bolt on's and n20, no cam
Old 08-16-2012, 03:55 PM
Cam99's Avatar
Perhaps I should push it over a cliff. Any other ideas?
Old 08-16-2012, 04:03 PM
2xLS1's Avatar
Get rid of the SLP MAF.
Old 08-16-2012, 07:07 PM
BLK02WS6's Avatar
Dry kit spraying on the MAF? SLP with a screen or not?
Old 08-16-2012, 07:36 PM
Cam99's Avatar
I can do that, but it does it with the maf unplugged as well
wet kit spraying after the maf. The maf has the screen
Old 08-17-2012, 04:07 PM
Cam99's Avatar
Ok. Installed a stock maf and a new TPS. No change. When it's cold started and in closed loop it runs perfect and a/f is 14.5 at smooth idle. as soon as it goes to open loop the a/f starts climbing till it pegs the meter at 21.9 and idle gets kinda rough. If you rev it the a/f reacts as it should but when it drops back to idle it leans way out again. does the same on very light throttle cruising
Old 03-17-2013, 12:09 AM
stioc's Avatar
Hey Cam99, were you able to find out the problem? I'm having the same exact problem (well the same exact symptoms) on mine. Thanks!
Quick Reply: low rpm/ light throttle surging
