big brake conversion
Old 08-19-2012, 02:08 AM
ls1sickandtwisted's Avatar
Default big brake conversion
Well i want basically bigger rotors and bigger calipers for my f body both in the front and rear but i need help i know wildwood and stop tech make the front ones but i was not able to find the rear ones so maybe they dont make them??? Maybe they do??? So i was thinking if im able to use the 2010 camaro brembo calipers or the CTS-V calipers or Z06 calipers both front and rear but also get bigger rotors also for the front and rear if so how big and what kind?? What else i need for the conversion besides rotos calipers and pads
Old 08-19-2012, 02:21 AM
Clearance is not a issue i have a set of wheels in19 rears and 18 front and another set of 18 rears 17 front so i can go with either set of wheels
Old 08-19-2012, 04:20 AM
cemlsx's Avatar
Check out Kore3 , they have a complete kit that allows you to use the C6 Z06 brakes in the front and back..
Old 08-19-2012, 06:50 AM
On theit site they only have the front ones but im gona give them a call to ask but thanks moe i got one more option
Old 08-19-2012, 09:56 AM
cemlsx's Avatar
I`m pretty sure they made brackets & adapters for the rear too..
Old 08-19-2012, 10:20 AM
z28bryan's Avatar
Looks like they might have separate kits for various GM 10 bolt rear ends. That being said.. how big are the rear C6 brakes? If they are a lot bigger you don't want too much rear brake bias when getting on the brakes hard or else you will have brake hop. And that can break your rear end. You will probably want to put a brake bias controller if this is the case.
Old 08-19-2012, 11:38 AM
For the C6 Z06 the fronts are 14" rotors and the rears are 13" rotors
Old 08-19-2012, 11:44 AM
Kleeborp the Moderator™
MeentSS02's Avatar
I'd advise you to print off some templates before you go thinking you have enough clearance just because you have larger diameter wheels - the spoke design plays a much larger role in whether or not a caliper will fit. You'll notice that fixed calipers, like the C6ZO6 and Stoptech ones, require more room to be able to clear the spokes.
Old 08-19-2012, 11:50 AM
I completely understand but i have some spacers here in my garage as well lol
Old 08-19-2012, 12:13 PM
cookba's Avatar
https://ls1tech.com/forums/suspensio...ll-w-pics.html
https://ls1tech.com/forums/suspensio...-kit-info.html
https://ls1tech.com/forums/suspensio...02-camaro.html
https://ls1tech.com/forums/suspensio...sion-pics.html
https://ls1tech.com/forums/suspensio...s-17-rims.html
https://ls1tech.com/forums/suspensio...-see-them.html
plenty of reading and plenty of answers.
Old 08-19-2012, 12:55 PM
Thanks im gona have to do some reading but i guess my question where do u guys find all the stuff needed
Old 08-19-2012, 01:33 PM
trans_am7935's Avatar
i would love to look into this. do you know if they use the drum type parking brake on these rotors?
Old 08-20-2012, 07:48 AM
furbe's Avatar
FYI here is the Wilwood rears...http://www.wilwood.com/BrakeKits/Bra...o&modeloption=
Quick Reply: big brake conversion
