Slotted rotors
Slotted rotors
Hey guys and gals,
I just bought some slotted rotors and had a quick question: what direction do they go? I've seen them on cars in both directions. I seem to remember seeing them on oem cars like vettes and porsches with the outermost part of the slots heading counter clockwise towards the front of the car.
Thanks in advance!
Thanks in advance!
LS1Tech Premium Sponsor
Hey guys and gals,
Thanks in advance!
Thanks in advance!
There are also internal vanes on a vented rotor. Sometimes these vanes are directional and will only create the correct vacuum when they're spun in the correction direction. Typically when this happens they have the rotors clearly marked.
Here is my GTO street setup with PowerSlot rotors.
- Kevin
Once upon a time, PowerSlot told me to install my slots on my GP so the outside of the slots point aft and the slots on the inside of the rotor point forward (totally opposite of that Goat pic above). I've seen other slot mfrs have them also "interlace", I believe they were DBA. There's also another slot pattern that looks almost like a Celtic Cross.
Keep in mind, PowerSlot is not longer the PowerSlot of three or four years ago. They're owned by StopTech now and have reformulated their metallurgy of their rotors and also the engineering knowledge behind them. If you don't have painted hats, you don't have the new PowerSlot design.
- Kevin
So mine turned out to go in the opposite direction of the ones pictured above. Installed and got some fresh royal purple oil in my engine. Good to go!
Next are the rear brakes. Do you guys suggest hawk pads out back too or just autozone it?
