5.3 horsepower list, singup now!!
Old 08-28-2012, 03:52 PM
Bobsmyuncle's Avatar
Default 5.3 horsepower list, singup now!!
With all of these "budget" and "junkyard" builds coming together, id like to see what we have out tree for high hp 5.3s. As people have talked before, the 5.3s are awesome on boost and do very well. I'd like to know how well. I jut finished mine up and was more than impressed with the results. Maybe we can get this stickied and get a good list of what great numbers are out there.
Looking for whp numbers
A quick rundown of your setup would be nice
5.3s only(no iron 347s)
I will maintain a list in this thread once I have some responses!
HANDLE----------------POWER ADDER------WHP---------E.T----------------TRAP SPEED
1.LSX3151....................BILLETT7675.......... .996.............N/A........................N/A
2.LS1NOVA...................PT88.................. ...954.............9.53......................150
3.BOBSMYUNCLE............GT4788..................8 89.............N/A.......................N/A
4.TRAVTECH.................GT4508................. ..876.............5.54......................128
5.SKINNIES...................BILLET7675........... ..855.............8.65......................167
6.DILSNICK...................7675 billet...............854.............N/A.......................N/A
7.ATOMIC 6..................TWIN T61.…............800.............N/A.......................N/A
8.TALON77...................COMP TURBO...........787.............N/A.......................N/A
9.ZGLASS.....................N/A.......................772.............N/A.......................N/A
10.BLACK98WS6TA.........47-80MM...............760.............5.64........... ...........121
11.SNIP........................PT88MM............. ...750.............8.90......................152
12.SW07GT...................PT7675................ .692.............N/A........................N/A
13.FONDLE....................TC78................. ...690.............N/A........................N/A
14.SILVER 92.................TWIN 66MM...........685.............8.55............... ........159
15.S13LSX.....................S475................ ...683..............8.76......................156
16.HYDROSTEAM6...........PT7875................680 ..............N/A........................N/A
17.W94RX7TT................PT6766................6 59..............N/A........................N/A
18.TRANSAM98..............S475.................... 633..............N/A........................N/A
19.night ryder................F1A.....................606.. ............9.99.......................139
20.WICKED69.................TWIN 62MM..........588..............6.21............... ........100
21.NIGHTMARETA............T76BB..................5 63..............N/A........................N/A
22.DENMAH....................80MM................. ..654..............9.95......................141
23.9SECTRUCK...............PT88................... .621..............10.70.....................143
24.CHIAJ144..................MPT70................ ..587..............10.50.....................133
25.TURBOCIV910.............GT4088................5 50...............6.50......................N/A
Old 08-28-2012, 04:09 PM
JAX04's Avatar
In! If my **** ever gets done ill be up on this!
Old 08-28-2012, 04:16 PM
Chicago TDP's Avatar
This is much like what I was requesting in the threads started by INTMD8.
Great idea to get all of the combos listed!
I am finishing up my JY 5.3 with a PT7675 billet compressor wheel.
Hoping to get on a dyno in a month or so.
Old 08-28-2012, 04:25 PM
LS1NOVA's Avatar
2005 L33 5.3, PT7675 .96 AR. stock 799 heads, LS1 intake.
824 flywheel on 16psi with LS1 intake and 224/228 114 cam, head studs.
717rw on 17psi through unlocked 4L80E, forged pistons and rods were added before the engine went in the car. 9.5 to 1 compression.
10.39 at 131 on 17" radials in a 3540lb 71 Nova.
Nowhere near done as Ive ran up in the 22lb area for boost on the street, no dyno numbers or track times for that yet. Expecting mid 9's and 800rwhp eventually.
Old 08-28-2012, 04:46 PM
js2fst's Avatar
Where is Skinnies and maxmitchell, red dragon might be there too!
Old 08-28-2012, 04:53 PM
silver_82's Avatar
iron 5.3
home ported 799 heads, (mild port job)
ls2 intake
twin 66mm turbos no intercooler
685whp on 14lbs
has run a 8.97 and as fast as 153mph with surging boost
Im currently working on a boost controler and building my own intercooler. And I expect to be whomping on it in a few weeks.
Old 08-28-2012, 05:47 PM
Moderator
denmah's Avatar
iron 5.3
stock heads, zr1 cam, pac1518 springs, stock truck intake
16psi s475
534rwhp 705ftlbs thru a unlocked th400 and 28 inch slicks
Old 08-28-2012, 06:07 PM
black98ws6ta's Avatar
Aluminum 5.3 with 799 heads stock. ARP head bolts and valvesprings only thing aftermarket in engine. Edelbrock proflow, 47-80mm turbo, 160 lb injector e85, powerglide, foxbody chassis, 3250 raceweight. 5.79 at 121 in the 1/8. Made 760 rwhp on my dyno. Over 25 psi to see those numbers.
Built the motor, added a camshaft....on limited passes went 5.64@126. Around 20 psi made 800 rwhp on my dyno.
Old 08-28-2012, 06:22 PM
list updated!
Old 08-28-2012, 06:48 PM
a4ls2goat's Avatar
havent dynoed mine yet as im just waiting for the 80lb injectors to come in the mail.
mods as follows
5.3 LM7
lunati dual springs/ comp pushrods
LS9 cam
GT45 turbo
gona be running on e85 on about 17psi
this will be on a 4000lb GTO
ill keep the thread updated when i go to the track
Old 08-28-2012, 06:57 PM
Ryans99ls1's Avatar
You should make it ET/Trap. i know im not the only person out there who looks at trap speed more than e.t.
i know you dont have a weight category, and you could add that.. but if its trapping pretty high on relatively low hp then we can just assume its low weight car. just a thought
Old 08-28-2012, 07:46 PM
KILLER-LS1's Avatar
also, this should be stock motors only (pistons, rods, and crank) Cam isnt a big deal. We all know a fully forged 4cyl can make 1000hp. Id like to see what the stock parts are capable of.
Old 08-28-2012, 08:02 PM
i dont see ur thinking here. we all have seen what the stock parts an do. its been the craze for the past year. if u havent seen it, u might live under a rock lol.
what u needa think about, take that stock 5.3 that makes 800+ and put rods and pistons in it and another 15psi. THATS what i wanna see. eberyone and theyre brother has seen a junkyard motor.\
sry but its the truth
Old 08-28-2012, 08:42 PM
TurboMark8's Avatar
I can see a thread eventually turning up -" stock crank highest hp" .....hmmm
Old 08-28-2012, 09:10 PM
atomic 6's Avatar
67 nova wagon, 5.3(L33) twin masterpower t61 turbos
18lbs, thru locked 4l80e, 800.1 rwhp.
e85, stock engine, taken from junkyard, knocked the dirt off, installed an '02 zo6 cam/springs, and boost. stock tty bolts, stock head gaskets, stock rod bolts, stock ring gaps, stock heads, etc.
No times yet(can't give anything away before DragWeek)
Old 08-28-2012, 09:51 PM
WheelsUp84z's Avatar
nasty wagon! what are those bypass valves?
Old 08-28-2012, 10:45 PM
turbociv910's Avatar
stock 5.3, gt4088, 550whp(th350) 6.50 1/8th
Old 08-28-2012, 11:17 PM
TurboMark8's Avatar
http://www.youtube.com/watch?v=KCzusdf7bkA
Any idea on mileage on that engine?
Old 08-29-2012, 06:40 AM
Moderator
denmah's Avatar
ah my friends car went 10.55 @ 133 off the foot brake,
i dont have dyno pulls or quarter runs for my fairmont yet but its a turbo 5.3 and it just went 7.10 @ 106.06mph on a 1.9 60ft haha only 15psi
Old 08-29-2012, 08:36 AM
trav-tech's Avatar
813whp 707ftlbs @19psi on a garrett gr4508r thru a th400. Motor has 232deg .595" 114lsa comp turbo cam patriot golds, home ported 243's 4.8 flat top pistons and gen lV rods with arp bolts. Vic Jr with elbo and 85 mm tb. EBay water to air ic. Best 1/8 mile time sofar 5.77@126 in a fox coupe.
Quick Reply: 5.3 horsepower list, singup now!!
