Eboost Vacuum Hose Joiner?
So, I bought a used eboost and its missing the adapter/joiner that connects the 4mm OD, 2.5mm ID polyurethane hose from the controller to the silicone hose that connects to the engine. 2.5mm ID is pretty small. It almost looks too small for a push-in style joiner. I'm guessing maybe its a compression fitting on the controller/polyurethane hose side connected to a barb on the engine/silicone side. Maybe I will have to go dig around at the parts store.
Can anyone confirm this? A picture of this piece would be extremely helpful. Turbosmart calls this piece the "connecting barb."
Thanks all!
Thanks all!
Found this little gem at O'Reilly....
Seems to fit perfect! Just an FYI in case anyone else is looking for this part.
Also, Turbosmart will mail a replacement of the original piece for $10 if needed.
There isnt really anything "special" about it. Just the size of the hole in it.
Ever look at the inlet on the back of any mechanical pressure gauges?
Same thing. It needs a restriction.
If it was better to have nothing, we would do it.
