11.0:1 compression on standard heads? is it possible?
was just wondering if it is possible for me to deck a set of standard ls1 heads to get my compression to 11:1
cheers
cheers
LS1Tech Premium Sponsor
What short-block are we working with, and which casting number heads are you about to mill?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Those heads milled .030" should give you about 61cc cambers. With GM head gaskets that should be about 11.1 CR. If you used Cometic .041" gaskets, that would put you around 11.4 CR.
Very possible. Up to around 12.75:1
I have stock bottom end with 243 heads milled to over 13:1, with 4cc valve releifs
If you milled the heads that much, the intake would not fit right and the bolt holes would not line up. I highly doubt you could use the listed cam and not have piston to valve clearance problems.
