New member ls-1 or 6.0??????????????
hello guys . i have a knocking 198.000 mile 98 ss z fig i spun a bearing still runs. FIRST QUESTION (remember on a budget kinda)should i rebuild factory motor or 6.0 both are gonna run me round 4 grand just dont know bout 6.0 working on ecm and oil pan .ect i know it will make more power i found one at local shop for $350 in a wreak van looked at stroker kit at tsp they $2200 i also plan on spraying the **** out of it. i can do the work just in dark on these motors any info would br greatly appreciated
I would rebuild the ls1 you already got...this is because I just don't like iron blocks in fbodies just because of the weight difference, if you do go with a 6.0 you can at least recoup some of the money from selling your old ls1...if you want it to handle keep the aluminum block ls1, but if all you want is straight line performance go with the 6.0...you can't lose with either motor! Now if you find an lq9 (high compression) 6.0 that is the motor to start with (ls2 aluminum 6.0 is top of the hill though as far as third gen LS motors)
No replacement for displacement... If you found a 6.0 for $350 I'd hop on it. Use the pan and acc. from your ls1 and drop it in.
People are making some ridiculous power on the stock crank so you could save yourself some money there and just get a good set of rods and pistons. Stud it all out and with a good tune you should be set...
Since I run one I'll throw a vote in for the 6.0l. 100 more pounds than the stock ls1, but if you feel the need you can drop that weight back down with a tubular cross member and lighter front suspension.
My take is if you plan to go for big power or boost go iron. If your not making considerable more power than the aluminum LS the extra weight will suck! My front end raised about 3" from swapping iron out for aluminum. It may only be an extra 100lbs or so, but it seems like so much more.
iam leaning more toward a stroked 6.0 only worry is my ecm being able to work on the 6.0 and injectors,crank sensor,being a 98 model i know it doesnt have the techology that a 02 has
ecm should be a plug and play for the ls1 and the 6.0, if your not making big power i would suggest staying away from the iron block. look into a 383 stroker with some 11:1 pistons if your looking to spend that much.
HELLO GUYS JUST WANTED TO LET YOU KNOE I HAVE CHOSE TO GO WITH www.cmengines.com THEY WILL DO MY LS1 FOR LESS THEN 2 GRAND THE CHEAPEST I FOUND AROUND LOOK AT THERE PRICES REALLY GOOD FROM WHAT I SEE DOES ANY BODY KNOW OF THIS GROUP I STILL PLAN ON BUYN A TEXAS SPEED CAM KITWITH SPRINGS WILL LET YOU KNOW AS I GO THANKS AGAIN GUYS
