LS1 fan ?
Old 10-09-2012, 08:37 PM
dmracing's Avatar
Default LS1 fan ?
What did you guys do for relay amp wise for the fans. Did you use one or two?
Old 10-09-2012, 08:56 PM
soundengineer's Avatar
one per fan.....any standard 30/40 relay will do.
Old 10-09-2012, 09:00 PM
dmracing's Avatar
I was told I could use one 70 amp relay for both
Old 10-09-2012, 09:01 PM
you need one relay per fan to turn them on separately.
Old 10-09-2012, 09:02 PM
74modified's Avatar
This is what I use for Taurus/Volvo fans
Old 10-09-2012, 09:07 PM
dmracing's Avatar
Its a carb car, no computer. Im not trying to argue but, I was told to tie the two together and use 1 relay to turn both on. Im using a temp switch in the head to turn then on. I was told to run the negative from the relay to the switch in the head
Old 10-09-2012, 09:09 PM
good diagram...
doing it like that makes it so that only one fan can be on at a time....
need power to go to 30 on both relays...and 87 to go to each fan...
the LS1 will want both fans on in high mode
stock pcm supplies a ground to enable the relay
personally, I prefer to use a 12v switched source for the relay to turn on instead of a ground to enable it...but you have to either have a separate switch, or be using a different controller for the fans.
Old 10-09-2012, 09:18 PM
74modified's Avatar
Yep, read it fast and thought he meant one or two fans not relays. Two speed fan should have one speed at a time.
No ECM then go here http://www.davebarton.com/pdf/coolingfandiagrams.pdf Several different setups
Quick Reply: LS1 fan ?
