How much are you guys paying to have the 2010+ camaro rotors opened to 70.6mm??
Old 10-10-2012, 09:04 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Default How much are you guys paying to have the 2010+ camaro rotors opened to 70.6mm??
I found a machine shop yesterday who can open up the hub diameter to 70.6mm and he quoted me approximately $65 a rotor to do it depending on setup time and tooling.
I looked at him like WTF and said they cost that new. He countered with let's see how long it takes.
So how much are people paying to have them modded to the correct hub diameter?
Old 10-10-2012, 09:58 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
C6 Z06 rotors bolt right up...
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 10-10-2012, 10:30 AM
UNDER PRESSURE MOD
They do, but the pads don't fit properly when using CTS-V 4 piston brembos and you also have to shim out the caliper due to the rotor sitting further out.
So I went with a rotor, as have many others, that was designed to be used with the caliper and pads and have the hub opened up from the 5th gen camaro size of ~67.xx mm to the 4th gen hub size of 70.6mm.
Old 10-10-2012, 11:00 AM
BMR Tech2's Avatar
I wasn't aware of anyone doing that. Indeed the pads don't sweep across the full surface, but there are actually many cars that come from the factory that don't - like the SN95 Mustang brakes. I'm curious to see the difference between the two as far as how the pads contact.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 10-10-2012, 04:02 PM
cookba's Avatar
i paid $40 per rotor and they look like they came from the factory. went with NAPA rotor (lifetime warranty)
Old 10-11-2012, 09:57 AM
UNDER PRESSURE MOD
Well, total was $137.80 to do both. OUCH. Oh well, thankfully I won't have to do this for quite some time considering I drive the car roughly a thousand miles a year.
Old 10-11-2012, 07:40 PM
Empatho's Avatar
I thought I over paid for mine when I paid $20-$25 each, I do not remember the right amount because it has been a while since I got it done. I can't wait to see pictures of your set up when its all done.
Old 10-12-2012, 10:43 AM
UNDER PRESSURE MOD
With any luck, I'll mock them up this weekend and measure for how much spacer I need. Once I get the spacer, I can complete the install.
Old 10-13-2012, 08:30 PM
Jenson's Avatar
Jeez!!! I would've done it for $50, sry you got raped by a local job shop. What's the part number for those rotors?
Old 10-14-2012, 05:42 AM
UNDER PRESSURE MOD
Where do yo live Jenson and do you have access to the equipment to do it?
I understand that it requires a rather large lathe chuck to be able to hold a 14" rotor and open up the hub diameter, and it takes time to do that setup, but I guess it came out to around an hour each rotor.
It is what it is. This hobby isn't cheap, so in the end, what's another $130 after spending as much as I have to setup the car.
Old 10-14-2012, 07:43 AM
Jenson's Avatar
It's honestly easier and quicker to setup on the cnc mill. I'm doing the same thing for mine and am going to make a 5x120, bolt the rotor down, and that's it. I also have a large manual lathe with a 6 jaw chuck that could do it too. If I make the fixture for myself, it'd realisticly only cost any one else $25 total now that I thijk about it. It'll be a 5 minute program. I found a cheap set of rotors from raybestos, should have them soon
Old 10-14-2012, 09:07 AM
UNDER PRESSURE MOD
Sounds like you have access to a lot of nice equipment Jenson. Honestly, I called around and didn't have much success, and once I found a guy who could do it, I pulled the trigger.
Old 10-14-2012, 09:28 AM
trans_am7935's Avatar
just out of curiosity, has anyone ever thought of turning the hubs down? like taking off your stock hubs, and have them turned down to 67mm instead of opening the rotor?
Old 10-14-2012, 12:14 PM
Empatho's Avatar
If you do that you would need to get new wheels or hub centric wheel rings, and if a spacer is needed you would need to find the proper hub centric spacer.
Old 10-14-2012, 12:49 PM
scj
scj's Avatar
You realized you paid $137.80 for <4mm...
Old 10-14-2012, 01:09 PM
UNDER PRESSURE MOD
Yes, I realize that, but it's not something I wanted to take a grinder to and just hack up.
Old 10-14-2012, 01:11 PM
LPE 403's Avatar
Some have spent more dumber ****......hell, that subject alone could be its own thread
Old 10-14-2012, 02:51 PM
LS1HIGHLIFE's Avatar
Wow, I only paid $20 to get both done at a machine shop in Richmond, VA. It was a 10 min job to do both on his lathe. I feel for ya man. Let us know how your set-up turns out.
Old 10-14-2012, 03:11 PM
UNDER PRESSURE MOD
Yeah, I overpaid, no doubt. Hopefully it's not something I'll need to do again for a while.
Old 10-14-2012, 04:08 PM
Jenson's Avatar
Plus you'd have to press out the studs to turn down the hub. A lot more work. Look forward to seeing yours done Alchemist
Quick Reply: How much are you guys paying to have the 2010+ camaro rotors opened to 70.6mm??
