Valve train noise
Old 10-17-2012, 11:38 PM
Hotrod350's Avatar
Default Valve train noise
Got an 06 1500 ccsb i just swapped my 4.8 for a 5.3. While i had the 5.3 out i put the ls6 cam Lunati springs and comp lifters. Used the stock pushrods. I have significantly more noise in the top end now. Is this mainly due to my stock pushrods?? Is this to be expected?? What's the preload supposed to be? Thanks
Old 10-18-2012, 02:51 AM
99Bluz28's Avatar
Yes, you'll need longer PRs with the LS6 cam. CompCam list the #850-16 lifter with a recommended pre-load within .030" to .040".
Old 10-20-2012, 09:21 PM
Hotrod350's Avatar
Are my stock pushrods 7.400??? You said .030 to .040?? That's it?? No wonder it's making noise. I've got a .050 smaller base cam and put tighter tolerance lifters than stock as far as preload is concerned. I was under the understanding that stock preload was .060-.080?? Is that correct
Old 10-20-2012, 10:03 PM
99Bluz28's Avatar
You don't have stock, you have CompCam lifters;correct..? So from 0-lash to 22ft.lb. 3/4 turn of the rocker bolt would be perfect at about .035 preload.
Old 10-21-2012, 12:05 AM
99 2500's Avatar
I recently put the 850-16 lifters in my engine and the instructions that came with the lifters called for preload between .050 and .100. I ended up with .070 and it's quiet.
Old 10-21-2012, 12:52 AM
99Bluz28's Avatar
This was the info I found:
http://www.compcams.com/Technical/In.../COMP4-116.pdf
Old 10-21-2012, 09:25 AM
99 2500's Avatar
My instructions says revised 3/22/12 so they seem to be the latest version, if you notice the instruction you posted say revised 7/20/07.
Old 10-21-2012, 12:04 PM
99Bluz28's Avatar
Okay, so disregard the .030-.040 pre-load; go with .050 -.100 .
Old 10-21-2012, 04:45 PM
Hotrod350's Avatar
Thanks guys. The stock pushrods are 7.400?? Or 7.390?? Not exactly sure.
Quick Reply: Valve train noise
