High compression with turbo questions
Was thinking I swapping to 317 72cc heads with a zr1 cam and a 70-78mm with a .96ar on my current 13.7:1 setup, by me switching to 72cc heads it would put me right at 11.7:1 with a.054 gasket and a dynamic of 9.19:1. Any opinions vehicle would have to run 110 or e85 which it does now. Need opinion before I start diggin to deep thanks
That's what I figure but my engine guy said I'm crazy it would be stupid to run a turbo with 11.7:1 wouldn't have any timing in it etc. so far I hae seen more than a handful of import and domestic guys doing this but need reassurance. any mote opinions or info guys keep it going
Right now a racetronix pump with 52lb that's it. I'm thinkin of running a inline 044 with the racetronix pump and I have a boost reference regulator from fuel lab and 90-100lb injectors. Any input on fuel pumps car is a c5 z06 auto swap
I'm not on pump now lol and I'm not trying to spend 600 on bottom end rebalancing etc I think I can get comp down to 11.249 with .060 gasket and polishing the cc of the heads. All I want is 600s
keep the .050 gaskets and run it, lots of guys (including myself) have ran boosted setups on high 10s to 11:1 on pump gas. Hell look at all these stock LS2's around with boost and they have nearly the compression you do. With E85 you can do a N/A compression of about 16:1, so think about that.
Hell I ran my 9.5:1 motor to 15# on pump gas with no intercooler
Id pick a different cam to run. The LS9 cam is gonna create a **** ton of dynamic and the thing has negative 22.5 degrees of overlap at .050.
A cam with the proper valve events will bring the dynamic down a touch and widen your tuning window when it comes to timing.
If you dont change it. Ill be surprised if you get 14 degrees in it.
The reality of it is..we put the static in it so we can run the big cams to get the cylinder filled as much as possible and still create a ton of cylinder pressure.
High compression with a small cam that has no overlap is gonna make for a overly sensitive motor on the tuneup.
