Oil pan?
Oil pan?
I have 72 Monte Carlo a-body. I've been reading up on it. An was trying to get some in put on what oil pan would be best. I have a lq9 with 4l60e. I'm seeing the 6.0 pan mite sit to low for stock ride height. Little help Thanks guys
I went with a cts-v pan in my 72 chevelle and it was TIGHT! I also had to have the motor sitting a little further back than stock so I have to shorten my drive shaft a couple of inches. If i were to do it over again I would spend the additional $200 and get the Mast or Champ pan. It would have been money well spent.
Hey guys I've been reading on the oil pan treads and stickies for two days an truly don't feel any closer to doing my swap. Never thought it would be this hard find a good pan. As I'm on a budget. I'm thinking of the cts-v pan for price. But how hard is it to get in there
There are only a few options and all of them have been used several times over, if you've read the builds I'm not sure exactly what you are looking for in terms of information? If you are asking "what is a cheap pan that will work well" then the answer is there isn't one; it's a matter or which acceptable pan is least expensive. Unless you have fab skills there is no way around spending some money. Maybe rework your harness yourself and put that money toward the oil pan.
Is your steering setup in front of the cross member or behind it? If in front, you could consider the corvette batwing pan as well. It seems they aren't popular in transplants, and thus might be cheap. My engine dropped right in with a vette pan (2nd gen f-body). As others have said, do some research and measuring first.
If you don't want to drop the $$$ on the sheet metal pans and you have a welder, go with the f-body pan, buy or make some 3/4" or 1" setback plates, and notch the cross member. You'll end up with zero ground clearance issues, no steering knuckle interference, and excellent stock baffling. Once you get past the first cut, its easy!
I just want to throw my latest expirience in. I bought a Holley retro pan for My 72 Buick. I liked the sump set up and that part fit nicely. The problem I have is that the front of the pan is 2.5" deep. I can not get the front of the engine down for enough to get less than 5 degrees of angle on the engine. I will either have to cut open the floor or change to a pan that is shallower in the front. As I do more research it looks like the Mast pan has 1.7 inches in the front but a larger sump. Checking into a Champ oil pan. I can not find the dimensions on the Champ pan anywhere. I have been trying to fit the engine with the Holley pan on it for over a month. I do not know if Summit will give me a refund on it. I have been thinking of modifying the Holley pan But at over $400 it is hard to just start hacking it up!
I completely understand why this is a problem. You can buy a complete 5.3 motor for $500 then people want you to pony up $400 for a stupid oil pan. I don't get it. I finally, hopefully have an f-body pan on the way for $210 then will probably have to modify it on top of that. This one part could easily be the most expensive if you don't get it right the first time.
Bottom line, no OEM Truck pan (without modifications) is an acceptiable pan to use on a Car swap. That is unless you have a stock or higher car and suspension !
CTS-V is can be used, but still will (most of the time) hange about 1" below the x-member. Will also need to move the engine back as far as you can get it (and up).
I bottomed out on mine and cracked it. 20 mile ride home in a Tow truck.. !
F-Body can fit, but is way to tight IMO, would not recommend it without notching it.
Holley and MAST are good recommendation for a Cast Pan, as is most of the steel pans.
these are just my opinons..
BC
BC
I spaced the frame mounts up, because I was originally using a modified truck pan which has the lower front area that interferes with the steering linkage. I am very happy with the modified F-body oil pan. The pan that you see behind the crossmember is the transmission oil pan, which would never touch anything unless you plan on going offroading.
First Pic: Engine in stock position for the original SBC, bolted to factory TH350 in the stock position, and using Edelbrock muscle car headers. C5 batwing pan dropped right in with no mods to the pan or frame, except me tapping a second oil drain (yellow arrow).
Second Pic: Trans replaced with T56 (can barely be seen in lower left), the engine still in the original location.
This is in a 2nd Gen F-body. Research fitment first. Your luck might not be as good as mine, but you can get a batwing all day long on ebay for less than $150.
