starter staying engaged after flexplate swap
Changed transmissions from a th350 to a glide. While trans was out I put on a Hughes sfi flex plate. Now the starter Bendix stays out for 3-4 seconds after the car is cranked.
What can I check?
What can I check?
UPDATE: this is the flexplate I have.
the one that everybody recommends from Summit.
http://www.summitracing.com/parts/at.../applications/
I have tried shimming. I had about .120 of shims and it still does it.
I'm thinking of trying the dished flexplate that came with my 5.3.
Can I use the spacer, that came with the A270 flexplate, in back (toward the trans) of the factory dished flexplate?
Or do I need to purchase the adapter hub for my turbo 400?
I had to change the 6.0 flexplate in my 08 van because it cracked.
I am going to pull the van starter and try it in my 5.3.
If it still hangs up, it has to be the A270 flexplate causing the problem.
The 5.3 is a 2001. I'm going to first check and make sure the 08 van starter is compatible.
I just checked advance auto parts site and it list two different part numbers for the different year starters.
Anybody know if my 08 6.0 starter will work in a 01 5.3?
I tried 2 new starters since mine was under warranty. Tried shimming too. Also new solenoid. No luck. I've just dealt with it since mine's a track only car.
Keep us updated, hope you figure it out
I found this...
http://www.s10racer.com/board/showthread.php?t=282
it states the late model starters will stay engaged using the jumper wire at the starter.
Like I have.
Gray86,
thanks for the tip.
Like I have.
Gray86,
thanks for the tip.
I found this...
Like I have.
Gray86,
thanks for the tip.
Like I have.
Gray86,
thanks for the tip.
Let us know if it fixes it and thanks for the heads up Tim
