how to switch over a 4l60e to a 4l80e
I got a 98 t/a I need a tranny to hold the power I put 390 to the tires on the dyno and I don't wanna spend 3k or more on a built 4l60e wondering what needs to be done for a 4l80e I have one down at work a buddy will sell me in a wrecked truck for 450$ it has 35k on it also wondering if I do switch will my converter work from the 60 to the 80
is there even a way to put a 4l80e in my t/a???? I thought there was a way just needed a new crossmember and shorten the driveshift I just didn't know if someone sold the crossmember and if there was more to it idk if the bell housing is the same or anything like that
Moderator
Do a search. Go to Advanced Search, enter "4l80E swap" and select the Automatic Transmission forum. There currently are 250 threads.
This is one of the most comprehensive ones:
https://ls1tech.com/forums/automatic...l80e-swap.html
This one starts with the question of what year:
https://ls1tech.com/forums/automatic...99-camaro.html
In short (and not exactly accurate):
* Pretty much any year, you need a 2WD version; pre 99 often preferred.
* Probably needs a rebuild with some performance parts and billet input shaft, especially if over 750hp
* Need a quality converter (about $1000)
* The tunnel needs to be pounded out a bit
* Lots of threads have crossmember suggestions
* Different yoke; might want a new driveshaft
* Changes needed to the wiring harness; many options described in threads
* Segment swap and/or other software/tuning changes to the PCM
The PCM changes are extensively covered in this thread, with the latest info near the end:
https://ls1tech.com/forums/automatic...-required.html
I know people have done the swap on a shoe string, but if I were to do it, I would budget $3000+ for it.
Once you get up to speed on the basics, post your more specific questions.
