Show off your turbo engine bay with a/c!
Old 05-22-2013, 09:22 PM
kylemm1002's Avatar
Default Show off your turbo engine bay with a/c!
Trying to get some ideas for a future build. I will be keeping ac an just need some pics for a good idea of turbo placement and if I'm gonna have to stand up the radiator or not. Also say if your using a oil return pump!
Thanks guy!
Old 05-22-2013, 09:28 PM
Cam72aro's Avatar
Here is mine. Gt91, 5th gen camaro manifolds, ac, stood up radiator, scavenge pump.
Old 05-22-2013, 09:30 PM
Cam72aro's Avatar
Here is one while fabbing. You can kind of see where the turbo is
Old 05-23-2013, 10:41 AM
Compressor Surge's Avatar
Old 05-23-2013, 10:52 AM
evo462's Avatar
AC, stock radiator/fan location, battery relocated to trunk.
Old 05-23-2013, 08:09 PM
Tally TransAm's Avatar
370ci, s480, ac, sway bar, acc's in factory locations
Old 05-23-2013, 09:55 PM
kylemm1002's Avatar
Keep them coming guy!
Evo462 have any more detailed pics?
Old 05-23-2013, 10:03 PM
Blackpanther99's Avatar
Very nice pics. I can get an idea of where to mount my turbo for my project.
Subscribing.
Old 05-23-2013, 10:15 PM
evo462's Avatar
Yeah I will upload some this weekend. I have a build thread too that had some others as it was being fabricated.
Old 05-24-2013, 09:04 AM
Hulkls1's Avatar
What manifolds did u use?
Old 05-24-2013, 09:17 AM
tony1784's Avatar
safe to assume that you need to have a tubular kmember too?
Old 05-24-2013, 10:25 AM
evo462's Avatar
Fbody manifolds facing rearwards with a BMR "turbo" K-member.
Old 05-24-2013, 11:33 AM
Reject's Avatar
this was my first ever kit
basically all it is is factory manifolds to the rear, driver crosses over to the passenger and merges together, from there its one larger pipe all the way to the turbine.
did this oh like 5 years ago.
the AC line is bent out of the way, was still working on that, but everything is in the factory spot.
Old 05-27-2013, 08:43 AM
BlackBirdDaddy's Avatar
A/C Turbo kit from Huron Speed. The install is super clean and the fit was perfect.
Water cooled (oil-less) Comp turbo CT-43 7879 billet ball bearing.
Pics are somewhat crappy.
(Here is the build thread: https://ls1tech.com/forums/forced-in...ird-build.html)
Old 05-27-2013, 03:03 PM
02sleeperz28's Avatar
^^^Very nice and clean setup.
Old 05-27-2013, 11:37 PM
evo462's Avatar
Vacuum block under the fuse block
Catch can in the front bumper
Pics from fabrication - all covered in DEI titanium wrap now
Old 06-22-2013, 07:33 AM
Reject's Avatar
it's cheap and fast as fkk. some people do both too....but we are all not that patient.
Old 06-22-2013, 07:44 AM
Cam72aro's Avatar
Because it works better at keeping the heat in.
Old 06-22-2013, 10:13 AM
This^^
Old 10-20-2013, 02:20 PM
kylemm1002's Avatar
Bump for more pics!
Quick Reply: Show off your turbo engine bay with a/c!
