Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
10 second combos..3500 lbs..NA
Old 09-03-2013, 10:27 PM
6D9
6D9's Avatar
Default 10 second combos..3500 lbs..NA
Been considering going the LS route for a bit. Most of the 10 second combos (budget type) are all in light 2800-3000 lb Fox bodys. For the money would the LY6 be the best route?
Something like this...
LY6
Vic jr
HP950
Custom Tick Perf cam
1 7/8 long tubes
3" exhaust
TH400...4000-4200 stall
3.73...26" DR's
Old 09-03-2013, 11:00 PM
In-Zane Moderator
ZONES89RS's Avatar
Onl thing I don't like about that idea at that weight is the gear. 3.73 will just not get it rolling as well as 4.10 or better. Otherwise you seem on track.
Old 09-03-2013, 11:52 PM
The stunningman's Avatar
Is your 3500 lbs including driver or not. That could be a "big" factor depending on the driver.
Take the easy route in your sig.
"72 240Z...6.0 LY6 in the works"
Old 09-04-2013, 12:29 AM
6D9
6D9's Avatar
Thanks guys for the info. So more gear then huh . Makes sense for the power curve these motors seem to have. I need to see what this 69 tips the scales at soon. I figured about 3350 or so.
As far the the 240z 6.0 I ended up having to sell it to pay some stuff off. Sucks...will build another one day!
Old 09-04-2013, 01:02 AM
topbrent's Avatar
Here is a link to a thread listing some successful carbed, L92/LS3, stock stroke, 10 second combos. https://ls1tech.com/forums/carburete...ide-cam-2.html
Here is the list.
Dmmizell: 2900lbs, 239/247, 110lsa+4, 9.87/137 - stock heads
87olds442: 3300lbs, 226/236, 110lsa, 10.79/121 stock ASA hot cam, LS376-515 crate engine.
Burgers: 3300lbs, 233/239, 10.56/127, CNC TSP heads
IheartLS1: 3700lbs, 239/247, 110lsa+4, 10.77/125- stock shortblock, CFM ported heads.
Jgillen91: 3400lbs, 235/251, 110lsa+4 10.72/126, CFM ported heads
3pedals: 3425lbs, 236/262, 110lsa, 5-speed, 10.90's@130
Trans & Converters:
Dmmizell: TH350, ultimate/ATI 8" treemaster 4500 stall
Iheartls1: 200r4, Ultimate 9.5" 4500 stall lockup.
jgillen91: TH400, 8" 4500 stall
87olds442: TH400, PTC 5200 stall
Burgers: TH400, Redneck 3800 stall
Old 09-04-2013, 01:22 AM
6D9
6D9's Avatar
Topbrent thank you very much for the info! That helps a ton.
Old 09-04-2013, 09:44 AM
I wonder whats up with the 87olds442 car. It must be one hell of a set-up (HOOKED) and lightweight to break tens at 121 mph.
My Fairmont in sig is 3200+ with me in it. It has a 2009 stock CID LY6. It runs 10.00 @ 135 mph When the heat isn't a factor.
High tens is going to take around 500hp and a proper set-up.
low 10's requires close to 600hp to reach your goal. So you need to be aware, your going to have to spin your LY6 pretty good to get there.
I have ran 10.0 @ 132 with the stuff you listed and stock long block LY6 (with a TSP 229 Cam) in a 3400+ lb dodge Dakota (Not aerodynamic at all) but that had a 150 hp sniper kit. Most consistent set-up I have ever had and a great driver on top.
Then I went on a N/A venture.
Old 09-04-2013, 08:48 PM
Old School Heavy
speedtigger's Avatar
LY6
Vic jr
HP950
1 7/8 long tubes
3" exhaust
3.73...26" DR's
Yep. Looks like you have nailed it. Going to run nitrous too?
I disagree. With a 26 in tall tire, he will run out of RPM in the 1/4 with a 4.10.
At 125 MPH with a 3.73 and a 26" tall tire and about 10% converter slip you will be at 6600 RPM. If he goes to a 4.10 it will put him at nearly 7300 RPM.
Old 09-04-2013, 10:04 PM
It just depends. Zones is right IMO N/A.
If he's going nitrous route then leave the gears alone and let the bottle build the torque. He won't need to spin it past 7000 IMO.
If he is going N/A and looking for low et numbers with only 364 CID , he has got to spin it to make the numbers. I have ran 4.30 gears with 26 inch tall slicks. The power is in the RPM's.
Old 09-04-2013, 11:53 PM
3pedals's Avatar
I agree, the squareport stuff likes to rev
Old 09-05-2013, 12:45 AM
6D9
6D9's Avatar
Thanks guys again for you opinions. For times mid to high 10's would be fine. Would like to do it on motor alone. Maybe nitrous down the road.
Old 09-05-2013, 05:29 AM
Z284thgen's Avatar
no 10's but i was close
ran 11:20's @125 @ 3400
Old 09-05-2013, 05:40 AM
Z284thgen's Avatar
stock 6.0 ported 853's comp shelf cam 4l60 yank 4k 4;10's drag radials
Old 09-05-2013, 08:23 AM
dogsballs's Avatar
Here is the list.
Trans & Converters:
thanks for this. as i've just got my engine running, 6.0 with stock heads 11.9:1 comp, e85 carb, currently 410rwhp on initial tuning.
2700lb, 236/246, 110 lsa
TH350, 10" 4500 convertor
only 3.45 diff, but will run a 28" tyre
aiming for low 10's
Old 09-05-2013, 02:36 PM
Old School Heavy
What is your MPH in the quarter? And what RPM are you crossing the stripe with those 4.30 gears and 26" tire? Remember Zone only runs 1/8th mile. Since the OP said he want so run "10s", I assume he intends to run the 1/4.
Old 09-05-2013, 02:47 PM
Old School Heavy
Here is the list.
Trans & Converters:
Did you compile this list yourself or is this from another thread/resource?
Old 09-05-2013, 05:20 PM
In-Zane Moderator
ZONES89RS's Avatar
Gonna take a trip to the 1/4 eventually. But with that much weight, it needs all it can get to get moving, a 3.90 is the hall medium, 4.30 is too much, but 4.10 with 3500 pounds all motor should work out. But I spin 7200 rpm.
Old 09-05-2013, 06:35 PM
I have been 135.20 fastest before the heat hit.
I ONLY RUN 1/4 mile tracks. I'm not interested in 1/8th mile racing on tracks that could run 1/4 mile events. Our track is trying out 1/4 and 1/8 mile points events this year. I am only in the 1/4 mile points.
I shift/ shifted 7500 rpms my limiter is set at 7900 it crossed the traps excess 134+ without a hint from the limiter.
Its all about the valve train set up right and the right cam. I am perfectly happy with the combo and have excess 100 + 1/4 mile passes on it and some street miles.
Old 09-05-2013, 07:25 PM
topbrent's Avatar
Hey Speedtigger,
I compiled the data on the list myself and need to update it, as there are some new cars/times to add to the list.
I keep notes on working combinations to look at trends and to figure out what is working well and what isn't.
It's interesting, informative and fun to look at the data.
Here is the link to the thread where I originally posted the list. . . . https://ls1tech.com/forums/carburete...ide-cam-2.html . . . .
Old 09-05-2013, 08:27 PM
Old School Heavy
I think the OP has a junkyard shortblock. I am thinking he is not going to want to see 7900 RPM. LOL
Quick Reply: 10 second combos..3500 lbs..NA
