Flexplate for 80e??
Flexplate for 80e??
Going to an 80e from a T56, and i need a flexplate. Which one should I get? I was trying to get one from summit because i can get a decent discount on them.. i was looking at this one
http://www.summitracing.com/parts/hu...make/chevrolet
Do you have to an a trans specific flexplate, ie 80e flex plate vs a 60e flexplate? need a quick answer. thanks!
1000rwhp street car
1000rwhp street car
Herrs the one i got J W Performance 93019LSD The Wheel Dished Flexplate
LS1-LS7 (P/G, TH350/400/700-R4, 4L60E/70E/80E)
Bolt Patterns: 10.75", 11.08", 11.5"
Requires .400 longer Torque Converter pilot 212$ shipped. When u have u converter made get the converter pilot .400 longer no spacer
This one? What size and type of converter are you using??
http://www.summitracing.com/parts/tci-399754
Having just bought a new TC from Yank for an 80 conversion, you can take two routes. You can buy a 60 style 3 bolt flexplate and have your TC builder make your new 80 TC come with that style mounting. This doesn't require any doesn't require any curved plate spacers or anything special.
Or, you can get a truck style curved plate, 6 bolt mounting, spacer required. The only advantage to this is that it allows for larger diameter TCs, like the ones found in trucks. Yank will only use the larger TC housings for their multi-disk units.
I went with their Pro-Yank single disk so it will work with the Hughes SFI plate that I used with my 60. Yank, Vig, Circle D, and probably others all can make 80 TCs that will mount on a 60 style plate.
https://ls1tech.com/forums/automatic...ate-4l80e.html
https://ls1tech.com/forums/automatic...l80e-swap.html
Bottom line, if you don't need a giant multidisk TC and aren't using a stock truck TC, stick with the 3 bolt 60 style plate.
