Flowmaster True Duals DIY Kit?
Anyone ever try using this kit from summit to build their true duals? It looks pretty comprehensive. I figure it can be routed over the axle and then use bullet mufflers like the Kooks system but at a much lower price and can probably be made quieter depending on which mufflers are used.
http://www.summitracing.com/parts/flo-815937/overview/
I have suggested this kit a few times , but you will need a few custom bends to complete the system.
https://ls1tech.com/forums/generatio...need-help.html
I agree, it does take time and patience. Here are the two kits that I built. First was a 2.5" H pipe and second is a 3" Xpipe. With the 2.5" I was able to retain the factory panhard bar brace, the 3" needed a relocation kit. I used round magnaflow mufflers on both.
The exhaust is aluminized tubing, the mufflers are stainless. I just welded them with a mig using steel wire. Here is a vid of the car at the track.
Custom 3" over the axle true duals. LS1 Trans Am - YouTube
poltergeist, do you get any drone/rasp at all with your system? It sounds great from the video.
