Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
gain of +11.75HP/14.0TQ From just wires
Old 02-07-2014, 05:30 PM
granatelli sales's Avatar
Default gain of +11.75HP/14.0TQ From just wires
Follow along as we baseline our 2014 C7 Corvette Stingray on our dyno and install a set of our "0" OHM ignition wires (28-1545HTRB). After changing the wires, we noticed an average gain of +11.75HP/14.0TQ.
For question or to order call:
805-486-6644
Old 02-07-2014, 05:31 PM
Direct OEM replacement, exceeds OEM specifications, OBD-II computer safe
Increase power to the spark plug up to 400% over stock
Customers have reported up to 15HP (normally aspirated) & 35HP (s/c, turbo, & nitrous). Average gains on an otherwise stock motor are 5hp N/A and 12 to 15 with factory forced induction
0 Ohm resistance, no RFI / EMI interference thanks to patented protector ring
Patented* design works with all fuel injection systems, street cars and race cars
Solid stainless connector cable with stainless snap lock spark plug connectors
High temperature silicone boots, 8MM jacket with fiberglass-reinforced braid resists temperatures up to 500 degrees f (1200 degree f. boots optional).
Ideal for use with aftermarket headers and/or turbocharger systems
Includes all necessary hardware
Over 600 fitments!
* Granatelli O ohm wires are patent protected by United States Patent number 7,185,622. This patent covers our unique method of producing ignition wires of extremely low resistance while maintaining very high noise suppression. The benefit of this invention is that full electrical energy from the ignition source is transmitted to the spark plug. The end result of the application of this method is increased horsepower, torque and fuel economy.
Old 02-18-2014, 01:18 PM
Old 02-28-2014, 04:20 PM
Over 600 fitments!
Old 03-26-2014, 12:28 PM
Back to back dyno tesing shows 10hp & 17ft/lb gain with the simple addition of Granatelli 0 ohm Ignition wires - Fits all LS Series engines
Old 04-10-2014, 11:17 AM
Greg Quillen's Avatar
added them but never got to dyno test it again since i forgot to bring them with me to the shop when they dynoed my car :-(
Old 04-12-2014, 01:35 AM
JeaneGrae's Avatar
Default Wires
So for the two versions of GMS wires shown in the vide with the Stingray, will they yield the same gains in terms of horsepower?
Old 04-15-2014, 02:25 PM
there the same wires just one has a protective sleeve on it we recommend them for people running headers
Old 04-22-2014, 01:02 PM
Sale this week on all Wire Sets
Old 04-22-2014, 05:44 PM
Chicago1's Avatar
What is the difference between the 3 different prices? Which would I need for my ls1 vette with headers and blower? They all say "High temperature silicone boots, 8MM jacket with fiberglass-reinforced braid resists temperatures up to 500 degrees f (1200 degree f. boots optional). "
but the 2 more expensive ones say high temp? Thanks
Old 04-22-2014, 10:23 PM
The highlander's Avatar
Does it come with calibration info on the actual dwell time for the coils? Coils will be discharged differently and will need different dwell times...
Old 04-30-2014, 02:46 PM
Granatelli Wire are Plug and Play
Old 05-09-2014, 02:18 PM
Old 05-21-2014, 12:33 PM
new video coming soon
Old 05-21-2014, 08:58 PM
BigBirdZ06's Avatar
cant see video says server not found
Old 05-23-2014, 12:06 PM
i think i fix it if not it is probley the forum you can always click that the name at the top of the video and i will take you to the youtube web page where it is located
Old 06-16-2014, 02:20 PM
Sale this MONTH on all Wire Sets
Old 06-17-2014, 09:19 AM
JeaneGrae's Avatar
Default Wires
Could you please PM or quote me on a set of black wires for a 08 coupe?
Old 06-17-2014, 03:02 PM
Pm sent
Old 06-30-2014, 02:45 PM
Originally Posted by Always2Slow
I have a set of these wires and they are the $200 variant with the hi-temp shields. Not only does granatelli stand behind their product with the warranty the wires will make a noticeable difference. I had a set of MSD wires before. Not only did they ohm out all over the place the quality control is absolute crap. I had wires breaking after 1 time of taking them off. I had to send wires back because they ohmed out more than a stock wire!
Straight for a customer
Quick Reply: gain of +11.75HP/14.0TQ From just wires
