Installing Pacesetter LT's On My Car
Old 04-23-2014, 06:42 AM
Birdracing's Avatar
Default Installing Pacesetter LT's On My Car
I decided to install my headers on my car I have a 94 Z28, got the manifolds off no problem, everything was going good until it was time to bolt the headers to the car. On the right side I had to remove the starter, alternator, and motor mount. Got the header installed than the EGR, on the back of the right header, would not line up. Had to remove the tranny tube, messy fluid running, on the left side I had to remove the steering shaft, and the plugs. Believe it or not I found the left side easier than the right. All I got left to do now is, bolt the Y-pipe and install the alternator, starter, and the plugs. Oh and install both the oil tube and tranny tube. Anyone know of an easier way to install headers on these cars? Idk if it is me or not but these cars are hard to work on, and I work on cars for a living..
Old 04-23-2014, 08:03 AM
jrwilliams95z28's Avatar
I had to do the same only I just unbolted both motor mounts and raised the whole engine for both sides. There's not really an easier way. I dident have to remove my trans dipstick because te T56 dosent have one
Old 04-23-2014, 08:52 AM
Village Troll
SS RRR's Avatar
Standard operating procedure for a LT install is to remove plugs, starter, oil sensor for pre-95 cars, steering knuckle and engine oil dipstick. Some instances with auto cars you don't have to lift the engine to get headers in. Six-speed the engine has to be raised off the mounts because the bellhousing is larger. Using a Canton 242T pan you may have to raise the engine and lower the k-member a bit to get the passenger header in without damaging a very aged and brittle heater box.
Old 04-23-2014, 09:41 AM
ZFreie's Avatar
This is my case,only thing I removed was the plugs so I didnt break them off, nose 4' in air and went right in from bottom.
Old 04-23-2014, 10:22 AM
big hammer's Avatar
geez. and those ebay cheapies that I bought fit in so easy.
Old 04-23-2014, 10:47 AM
Village Troll
SS RRR's Avatar
I bet the dropped right in from the top without removing one single valve cover!11
Old 04-23-2014, 03:11 PM
BSmiff's Avatar
I have all that **** off mine and I still have to lift up the right side with a cherry picker to get clearance. **** wont go in from the top or bottom. Im pretty sure my mounts are fucked but there is a bolt broke off in the mount motor-side so them bitches is gonna be in there for a while.
Old 04-23-2014, 03:15 PM
Catmaigne's Avatar
I pretty much removed everything around the motor (steering shaft, emissions stuff, dipstick, starter, alternator) but never had to jack anything up or touch the mounts. Wasn't that bad but. My car is m6.
Old 04-23-2014, 04:08 PM
KyleW707's Avatar
Tf??? I put mine in from the bottom and the only thing I had to remove were the spark plugs.
Old 04-23-2014, 05:13 PM
smitty2919's Avatar
Mine was hell...I had to buy my car to get L/T's on.
Old 04-23-2014, 07:28 PM
Birdracing's Avatar
When I jacked the motor up on the right side I slipped the header down from the top no problem slipped in like a glove. Tried to reinstall the tranny tube today kinked while I got it back in place, now I can't get the stick down into the tube. Here is a question for you guys did ye buy O2 extensions or use that kit who bought Pacesetter's with the O2's? I think I am buying extensions myself I don't want to butcher the O2's..
Old 04-23-2014, 07:36 PM
Catmaigne's Avatar
I soldered my extensions at first and they worked great... that is until a really heavy rain storm got into all of my wire insulation and created a short. Just buy the extensions.
Old 04-24-2014, 07:32 AM
Village Troll
SS RRR's Avatar
Different styles of LT's may not have the same kind of angles on the primaries, so getting them into place may be less of a challenge than other LT brands.
Buy the extensions. They're cheap and easy.
Quick Reply: Installing Pacesetter LT's On My Car
